DNS over TLS/IPv6 issues- Apps don't load data over Wifi
Would anyone be interested in the workflow i created that checks if v6 is available as soon as the screen gets unlocked? I used tasker and shizuku on unrooted phone. Its just some QoL and only really viable if you don’t reboot the phone as shizuku needs some adb prompts to be able to toggle wifi. Insane how locked up Android is by now, Tasker sadly became very limited.
The task checks IPv6 connectivity by making an HTTP request to ipv6.google.com. If IPv6 or the tasks itself fails (based on HTTP response code), it restarts Wi-Fi using svc wifi disable/enable. Happy to provide the xml if allowed.
This unfixed v6 issue and lack of communication by Fairphobe really is a pure joke by now.
Ok.. for the people who have access to a somewhat decent AI model. I’ve created a dev version of an .apk that forces IPv4, so I don’t need to use actual VPN running all the time.
In summary, give this prompt to your AI:
Drop into any capable AI (Claude, ChatGPT, Gemini):
> **Build me an Android app called "IPv4 Enforcer" that forces my phone to use IPv4 only.**
> Use Android's `VpnService` API to create a local-only VPN (no external server). The approach:
> - Set a fake DNS server IP (e.g. `10.99.0.2`) and only route that single IP through the TUN interface — this way only DNS traffic enters the VPN, avoiding any traffic loop
> - Intercept DNS queries, forward them to `8.8.8.8` over the real network (using `protect()` on the socket), strip all AAAA (IPv6) records from responses, and return only A (IPv4) records
> - Run as a foreground service with a persistent notification and a "Stop" action
> - Simple Compose UI: toggle button (Start/Stop Protection) + status indicator
> Stack: Kotlin, Jetpack Compose, Material 3, minSdk 28, targetSdk 35.
> In the manifest, add `foregroundServiceType="specialUse"` to the service and the `FOREGROUND_SERVICE_SPECIAL_USE` permission to avoid crashes on Android 14+.
Install the .apk on your phone and enable.
The latest update FP6.QREL.16.82.0 doesn’t fix the issue.
Interesting, as it mentions a fix for loading issues of some apps when connected to Wi-fi.
Edit: Well in German it says they solved this problem but the English release notes say they improved loading times of some apps while connected to Wi-fi. :thinking:
It still doesn’t work for more than a few minutes when using IPv6 (when connected to Wi-Fi).
It looks like Google Pixel users might be joining the club: Some new Android 17 users report bizarre Wi-Fi problems in apps
Maybe it will expedite finding the fix, but I wouldn’t count too much it, Pixel users are used to things being broken for a few months.
They def did not fix this ipv6 issue, and in the beta group I didnt get a response what this mentioned fix is about.
At the moment all problematic apps as well as IPv6.google.com and test-ipv6.com are working.
I’ll see how long this will last.
Interesting.. installing update now…
Still working after Eight hours…
Problem’s still there :weary_face:
After the update it seems stable here too
I can’t recognize any improvements or any changed behavior so far.
Everything’s still working here.
Crazy, I just checked again and it seems to work for the last hour.
Still working two days after the installation.
On my device is OK now since the update
I’m with T-Mobile Germany still on Version 16.69.0. No Update here.
Seems to be back again ;(
Now it doesn’t work anymore without the workarounds since this morning. Strange.
