DNS over TLS/IPv6 issues- Apps don't load data over Wifi
Still working.
Although I have to admit that my phone isn’t connected to my WiFi 24/7, so it gets reconnected from time to time.
I have reenabled ipv6 on my router just under 24 hours ago, and it is still working after the latest update.
On my device is the Bug Back again
Yes - I have the bug back again - it seems it was much slower to appear this time.
The latest update is not fixing the issue, no words… I’m starting a Notice of Defects with the retailer I bought this device from (Media Markt, Germany) because of this software issue. I’ll let you know how this goes, if anyone considers doing the same.
Keep us updated. It’s bewildering the problem persists, but to not only fail to communicate openly about it but also mark the closest sounding issue as closed when it isn’t fixed, is unacceptable.
Dear community, thanks for having me here!
I am having the same problems discussed here. The update 16.82 did not help. My idea is that switching access points on the same Wifi ID forces this. At home we have 3 AP. At work we have numberless (eduroam at (German) universities). Both networks the same problem and both with IPv6 turned on, no chance to change that.
I will follow here what comes next.
PS I have some colleagues with FP6 on eOS. Are there any reports on this combination?
Greetings, Sebastian
I have another data point that may help narrow this down.
My setup is:
Fairphone 6
FRITZ!Box 7590
Deutsche Glasfaser (native IPv6, delegated /56 prefix)
When the issue occurs:
the phone still has valid global IPv6 addresses (2a00:…),
the IPv6 prefix is still present,
link-local and ULA addresses are also present,
but test-ipv6.com drops to 0/10,
ipv6.google.com is unreachable,
reconnecting Wi-Fi immediately restores IPv6 connectivity.
So the phone does not lose its IPv6 address. Instead, it appears to lose IPv6 connectivity while retaining valid global addresses.
I also tested the recent update FP6.QREL.16.82.0. Initially it looked promising (everything worked for several hours), but after leaving the phone connected to Wi-Fi overnight, the problem returned with exactly the same symptoms.
I also disabled “Advertise DNSv6 server via Router Advertisement (RFC8106/RDNSS)” on the FRITZ!Box. This seemed to improve the behaviour of some affected apps (e.g. Finanzblick), but it did not prevent the IPv6 connectivity failure.
This suggests that the issue is probably not caused by missing IPv6 configuration (SLAAC works), but rather by a failure of the IPv6 data path after prolonged Wi-Fi uptime (e.g. default route, neighbor discovery or a related network stack issue).
I also compared it with a Samsung Galaxy A54 running Android 16 on the same Wi-Fi, the same FRITZ!Box 7590 and the same Deutsche Glasfaser connection. While the Fairphone 6 showed 0/10 on test-ipv6.com and could not reach ipv6.google.com, the Galaxy A54 scored 10/10 and had fully working IPv6 connectivity.
This suggests that the issue is not triggered by my router or ISP alone. Under identical network conditions, different Android 16 devices behave differently.
Check the issue in the Google bug tracker, the exact cause is already known. You can read the code and see exactly where it is going wrong when a router advertisement with lifetime 0 is sent. Furthermore, there is also a fix in the issue tracker.
In the best case, the fix is already known to FP and they are validating it. Worst case, it resulted in new issues.
Okay, I must’ve missed that.
No worries, I thought I’d mention it in case you’d like to dive deeper.
Interesting! I will test this, will report back in a day see how if it works.
Sadly after just a few minutes, it broke again.
Someone in the LOS topic reported the same…
That might mean that the issue in the google issue tracker, where so many people spammed the comments, is not the actual problem on FP6. It sounds plausible since that issue is there since Android 14 or earlier as mentioned in the issue description, and this FP6 issue is new since Android 16 from what i read?
Yeah, this was I was afraid of, as I could not find a RA lifetime 0 in my tcpdump. So while the issue in the Google tracker is real, the effect seen here could be something different/additional.
My wifi is still broken. Nothing was fixed. Dammit. I will have to keep it off while I am at home. Very disappointing.
