I should see that an “N” should come up in the above screen when connected to the pc - nope…
the fp2 doesn’t show up in the pc either…
dreaming of a google mobile where the microphone works, the pdf can be opened, and so on - although you are tracked constantly … so annoyed about these f… consumer friendly menus where every simple issue takes you HOURS to get it done … if at all
thought it has to be due to Ubuntu mate - but on an older Ubuntu version on the laptop the same issue…
I’m not quite sure I understand? So you use a FP2 and datatransfer does not work? Are you sure you use a data cable? Did you try different cable and USB Ports? Do you see anything in the settings under connected devices?
