Customize home screen
Hi I tried to customize my home screen on my fairphone 5 e/os. Still on android 13, no updates available. I tried to do all according to the support page of fairphone but nothing works, I can’t make folders or rearrange the apps. All the apps I download get on the homescreen and it is getting quite a mess since I can’t organize… It’s been like this with and without sd card. Supposedly you should swipe up from the homescreen to see all the apps, but if I swipe up nothing happens.
I hope someone can help me.
Melissa
Welcome to the Fairphone community forum :slight_smile:
Firstly, since you’re running /e/OS (Murena), you’ll likely find more info and discussion over on the /e/OS community forum.
That said,
  • On the question of Android version, see this over on the /e/OS forum:
    Will my Fairphone 5 get an OTA upgrade to A14? - Fairphone - /e/OS community
  • Arranging shortcuts on the home screen.
    The app that manages the home screen (called Bliss launcher) is designed to be as simple as possible, but that means substantially reduced possibilities for configuration. All the apps appear on the home screen, so there is no need for an app drawer (that you have in standard Android by swiping up from bottom). No folders etc. Home screen pages (swipe left and right) fill up from top left. You can’t leave gaps, but you can create more pages before the last one is full (as many pages as you need).
What you can do:
  • Distribute the shortcuts on different pages. Hold and then move a shortcut to the right edge of the screen to reach the following page. That enables you to group shortcuts on different pages according to theme, often used, or what you want. To create a new page, just swipe the pages to the left until you get to the last one, and then move a shortcut to the right edge of the screen so that it falls onto a new page. Pages must have at least one shortcut or they disappear if empty.
  • Before you install a new app, first go to the home screen page where you want to put the shortcut. The shortcut is always added to the page of the home screen you last visited.
  • Page 0 (the LEFTmost page) contains an Edit button for installing widgets from your apps.
Otherwise, you can install an alternative launcher app such as Lawnchair (the pun is not mine :wink: !) or Nova – there are dozens to choose from. Search “launcher” in both forums to get an idea of what people think.
[Edit] – a word about SD cards. Please read the Forum Guide on the subject and also this topic.
Thank a lot for the information. It was all I needed and didn’t found or understood!
Hi Melisa
I’m Steve in the UK
I am no expert but I had a similar experience until I installed Nova Settings from the App Store.
Once it’s installed and run it is very easy to use and you can customize settings to suit your requirements.
Good luck
You don’t own an e/OS/ to install apps (that for this one requires 30 authorizations) from google store I guess…
For comparison, fossify launcher from f-droid, which gives a similar launcher as the Fairphone os one, only requires 1 authorization.
