Hallo.
My girlfriend has the charging Problem, too.
The Fairphone shows the charging Symbol, but the FP1 didn’t charge.
Software version is 1.8
In the Phone is a “SanDisk Ultra Class 10 Micro SDXC 64GB” Card
Tuffi
Hallo.
Tuffi
Same issue here. Before the 1.6 update I never had this issue.
A 64GB card is in use, and has been since day one.
The issue is as described by many above: roughly in 20% of the cases, cable/charger independent… I’m now used to look at the % when starting to load, and look again after 10-20 minutes to see if the level has gone up. If not, I reboot the phone, which helps in 99% of the cases.
I found out that while the charger do not work, the laptop does. But I experience the same problems as described here.
And another thing: How can I choose in which mode the USB-port should be used? I sometimes do not get the menu to choose between “only charging” and “media”, and then it seems I cannot change the setting manually.
I still have the problem described above - has anybody found a solution / gotten a reply from the support team? I never charge via laptop, only by “wall” electricity plug. I am certain it is not the cable, I used several different ones to test this, but the problem randomly occurs with any of them. To sum up, once again, problem as following:
If any of you have ideas how to fix it, let me know, otherwise I will contact the support team (and will happily share answers if needed)!
I have experienced the same symptoms as described by Anna:
About three times a week the phone would not charge althogh the red LED indicates charging. The battery percentage did not change while connected to the charger. After unplugging the cable the percentage dropped below the initial percentage.
I first suspected the fairphone case causing connection problems with huge Micro USB Plugs and used a cable with a smaller plug, but taht did not improve the charging behaviour.
I have now bought a new charger, and have not had a single charging problem for over a month now.
I do not want to promote buying this charger as the perfect solution for this problem, but for thise who want to try, it is a Anker 5-Port USB Charger Model Description.
If you are just using one device, you might opt for a smaller model, but if you are charging / operating fairphone, tablet, work phone, RaspberryPi etc at the same desk, it is quite a neat solution.
I have this problem as well and can add the following observations:
“The discharging while the charger is plugged”-problem only happens for me after a reboot when plugging the charger for the first time (to a USB-port (500mA)). Unplugging and plugging it again will make it charge. (My fairphone is turned off at night)
Problem 1) does not happen when plugged to a stronger charger (1A)
Recently (due to a dying battery?) the replugging trick doesn’t work anymore. I assume this is because there is too many (background) applications running which consume more than the charger provides for charging and running.
Maybe everything is related to problem 3).
Dear all,
as promised I am sharing fairphone help desk’s response with you guys (thanks Esmee). I hope it helps - if it does not, please also post this here!
Best, Anna
Email from help desk:
I have reported charging problems early April.
A couple of weeks later my battery started to loose capacity and it was was bloated.
I have reported it to support and received a new battery.
Maybe there is a connection between the two issues, so keep an eye on the shape of your battery!
Thanks for mentioning it again, @janomat!
A bloated battery is dangerous because it can explode!
Hi Fons!
I have exactly the same problem with my Fairphone 1. Did you find any fix for it? Would be amazing if you could let me know !
I have the same problem and find no solution…
For me that solution worked (originally meant for samsung galaxy though but who cares
http://forums.androidcentral.com/google-samsung-galaxy-nexus/285706-galaxy-nexus-only-charges-when-phone-off-dosent-when-help.html#post2882737
Have always had this issue with my fairphone, now it has gone totally flat and refuses to charge at all, i will have to buy a new phone since real support is nearly impossible to find for fairphones. So much for making a difference by buying an ethical phone. hopefully the new fairphone is not a piece of junk like the first one
…not that i will be buying a new fairphone
Sounds all like battery problems.
Mine was exchanged by support without any problem, so there is indeed support
these support forums exist because many people have issues with their fairphones. hopefully many of those issues have been addressed with the latest release
This community-led forum exists for community-support and -discussions. And you didn’t post about your current problems before stating “real support is nearly impossible to find”. It sounds like your battery is dead although you didn’t give much information between all that BS about how much of a “piece of junk” the fairphone is!
If the environment means anything to you please contact Support to get a battery replacement instead of buying a whole new phone. And if you have any other problems contact support about them too or post them here on the forum (with more details than devastating generalizations please).
yes Paul… because people are going to wait weeks for a replacement battery while having no working phone…hardly likely for anyone let alone myself as i am currently tethering pc internet from a mobile phone. I have contacted support, suggested reply (let alone action) is 3 days. my fairphone was under spec when it was released, i was aware of that when i purchased it but still did so. this is my first smartphone because I waited for an ethical one to be produced… meanwhile what were you using? an apple perhaps? hold the judgement.
the fairphone is well known to have a multitude of issues, nothing is perfect and early days yet, as stated previously I really do hope that the issues are resolved promptly with the subsequent releases. I would hope that fairphone is able to hold its own, rather than just being suggestive to other manufacturers that there is an ethical market (in itself a good thing)
less than 1 year in and my phone is completely non-functional, that is sub-standard. hopefully i can get a relatively prompt and inexpensive remedy to this situation. I will still have a phone that does random things, often has no idea where it is (even after the ridiculous amount of forum suggested gps fixes), has a substandard camera, not enough ram etc, intermittent charging (not uncommon according to this forum)… that is the price that i paid, but i still expect the phone to work less than 1 year in
perhaps instead of just being a defensive fanboy you could (as a moderator) link me to where I would purchase a battery, it does not appear to be listed in accessories or spare parts (have to assume i am missing it as it is an odd, concerning and unlikely omission )
http://shop.fairphone.com/catalog/category/view/id/11
thank you
