Best USB-C to Audio Jack Adapter for FP4
Hi all,
I’m interested in a Fairphone 4. I can live with most of the technical trade-offs vs. other devices, but the main hurdle left for me to overcome is the lack of 3.5mm headphone port. I have some quality IEMs, and so have no interest in wireless buds/phones.
I know a lot of people have complained about FF’s decision to drop this, but it does seem a highly questionable one. So my question is: what’s your experience of using wired earphones with the FF4, via some adapter? Which adapter do you use, and do you find that it breaks and you have to replace it?
I was reading up on USBC-to-3.5mm adapters and it seems it’s not straightforward which you need, plus they often seem to break. It’s another moving part in the chain, after all.
Many thanks in advance!
You better get used to it. The whole industry is heading wireless, let’s face it.
Best wishes,
Thomas
Hello and welcome to the forum. Take a look at:
From my exprience it’s completely fine and the adapter (a cheap one from AliExpress) still works fine, but I don’t use it that often.
In my limited experience, the adapter sold by Fairphone is quite good, as good as an adapter can be (it works and is quite solid, that’s all I ask for).
Note I mostly use that adapter for the old office headset I use when I need my hands on the mouse & keyboard while being on the phone (yes, I could use the earbuds, but the wired headset doesn’t use batteries…).
I have not yet figured out the best USB-C option for my phone, but I wanted to share some thoughts based on what I have researched.
First, a lot of the adapters with a built in DAC (which is what you need with a FP4, while some phones can send an analog signal over their USB-C port, in which case a simple passive adapter is all you need, but won’t work here with FP), and thankfully so many of the USB-C adapters have decent to great sounding DACs built into them. People usually throw around the Apple and also Samsung adapters as the best sounding cheap dongles.
However, there are a bunch of technical quirks and details that make it a lot harder to find a perfect adapter. First, I don’t remember all the technical details and terminology, and some of it probably is already covered here on this thread (because I remember reading through this thread at some point when researching). Basically, there was something about the Apple and Samsung adapters that didn’t completely follow the procedure and standards of how sound delivery over USB-C is supposed to be done, which results in a total max volume drop on many phones (maybe a 20% reduction or so?), and I think FP4 is one of these phones. Second, if you live in Europe, these adapters are further affected by some regulations in EU, which means that the European versions of the adapter have a reduced power draw that results in an even larger reduction in volume compared to the adapter sold in the US.
I used the Samsung adapter for about 3-4 months, because I read it was a bit less affected by these factors, while the European version of the Apple dongle would have as much as 50% drop in volume it could produce. Still, I noticed that when with my older phone with a headphone jack I found comfortable listening level to be just around the mid point of the volume scale, with the Samsung adapter on FP4 the same level was around 3/4th of the scale.
I largely stopped using the adapter because it became so sensitive to any sort of touch or nudges that it would constantly cut the music playback, and I think it’s due to something in the adapter itself being wonky or starting to break, because I still don’t get any disconnects with the phone when charging or moving data via USB cable and heavily shaking the cable (meaning, it’s probably not due to the USB port in the phone, nor is it due to the plug tightness of the adapter as I did tighten the grip of the plug with some pliers).
Otherwise I thought the adapter sounded wonderful and pretty neutral (no strong coloration in the voice, clear bass, mid range and treble), it also supported the mic/handsfree button of my headphones if I wanted to pause a song or skip it. The volume level wasn’t an issue for the most part, but some music with much wider dynamic range was just barely at comfortable volume levels when maxing the volume scale. Unfortunately, if I wanted to touch up the sound even a little bit with EQ, there just wasn’t enough headroom in the volume scale.
I have understood that you can get the best results weirdly enough with some Chinese brand adapters that use a specific type of DAC chip that’s very widely used by many generic adapters. Get one that seems to have a sturdy build, and since they are made by some random small brand, they apparently do skirt around some of the regulatory factors that have affected these big brand adapters.
Don’t know about the policies on this forum about linking stuff, so I’ll just say that some of the more technical information about DAC chips I found on audiosciencereview forums.
I’m not currently using any USB-C adapters since I’m still trying to figure out what adapter to get and where (in Europe) I should buy one. I’m just using some old Nokia handsfree Bluetooth receiver to connect my IEMs for casual listening.
It seems that this thread has mostly talked about adapter’s without a splitter for charging purposes, but I’m hijacking it for that purpose anyway.
I am currently looking for two different kinds of adapters that have been confirmed working with the Fairphone 4, that allow me to connect my headphones to the FP4 while charging simultanously:
  • The first type of adapter is USB C (male) to 3.5mm (female, audio) + USB C (female, charging). I have only seen the Belkin RockStar model mentioned above. Any comparative experiences in that area?
  • Secondly I’m looking for USB C (male) to USB C (female, audio) + USB C (female, charging).
Additionally I would ideally like to have a single-cable solution that works to connect my Bose headphones with a 2.5mm plug to the Fairphone’s USB C port, in order to avoid constantly loosing adpters - so 2.5mm (male) to USB C (male).
Do you guys have any experience with these kinds of adapters and can confirm which models are working (well) with the FP4? I would prefer to avoid unnecessarily buying incompatible adapters.
Did you check the list or only this topic
Oh, no. I only checked this thread itself at first, sorry. The wiki should at least take care of the charging + 3.5mm splitter.
As far as I can tell there’s no entry for a USB C to 2x USB C splitter for audio + charging though. Any experiences with that?
I have some updates to report regarding adapters I tried:
Let’s start off with the best experience - this USB C (male) to 2.5mm AUX (male) cable by MOSWAG for use with my Bose QuietComfort over-ear headphones. The cable seems to work flawless when connected directly to the fairphone. The only downside I noticed is, that the 2.5mm side of the cable does not sit in the headphone plug as firmly as the original one - potentially due to the larger rim directly below the connector.
Now for the USB C splitters. I’ve so far tried two of those:
First off we have this two-way USB C splitter (1 charging, 1 headphones) by TRANSLIKS. When my FP4 has a significant amount of charge left the adapter works flawlessly with my default chargers for charging-only, headphones-only and both at the same time. However, if the battery has less than 25%-30% of charge left, a curious thing happens (depending on the type of charger used). For my old Motorola (Nexus 6) and Apple (iPod Nano 4th gen) chargers, the connection seems to disconnect and re-connect in short intervals once the charger is connected, which also interferes with the headphone functionality. With my Laptop’s charging port and a more recent OnePlus charger on the other hand it worked fine all the way down into single-digit battery percentages.
Secondly I tried this three-way USB C splitter (1 charging, 2 data) by MOSWAG. While listening to audio output and charging at the same time did work with this one when I tried it, once one of the two was disconnected the other one stopped working as well. Also charging, listening to music and transferring data to my laptop in parallel is not a task this adapter seems to be able to fulfill with my FP4.
Finally I tested a USB C to USB C (charging) + 3.5mm AUX (audio) adapter by the FP4. I chose this adapter/splitter by Tomost since I quite like the ‘parallel’ design of it, almost giving it the feel of an internal audio-jack. Unfortunately the audio jack seems to be incompatible with my FP4 - tested again with my Bose Quiet Comfort headphones.
So much for that. I hope some of you find this follow-up information useful - especially the USB C splitter stuff, since nothing had been reported regarding compatibility with those so far.
Not sure this is extremely helpful, but just tried an unbranded power/headphone splitter from ebay (unfortunately before finding this post!) and the headphone socket didn’t work (continued to play sounds out of FP4), the charging port worked though. :person_shrugging:
USB C Type C Up to 3.5mm Headphone Jack Male Aux Audio Adapter Cable
Hello, I bought an audio adapter that allows to connect my fairphone from it s USBc entry to a jack so as to connect my music to my car radio (that doesn t have bluetooth).
It doesn’t work, the sound still comes from the phone and not the radio when connected…
Hi and welcome, i moved your post here maybe you find answers above or this list
I have been using a Fairphone 4 for a year now. So far so good, except for that major flaw that seems to have annoyed many users: the absence of an audio jack output. Besides creating the need to buy an adapter every few months because they get ruined in my pocket (which is not a very eco-friendly behavior), there is another problem which is that I can’t listen to music and charge my phone at the same time. It is particularly problematic when travelling, especially by train because I want to take advantage of the outlets in the train to charge my phone while listening to podcast.
I found an adapter that has both an audio jack and a usb-c output, which can physically answer my needs. However, the problem is that my phone does not recognize it as an audio device, so it keeps outputting sound out loud even though some earphones are connected.
So my question is, is there a way to force the phone to output sound through usb-c?
There is a “Disable USB audio routing” option in the developer options, I need the exact opposite (something like “Force USB audio routing”).
I know you probably haven’t owned an iPhone with a lightning adapter and headphone jack combo adapter. There are adapters out there that allow charging while listening via AUX cable. If you don’t believe me look at this Amazon listing I’ve found. There is only a few adaptors that doesn’t work on name brand phones like Samsung Galaxy. The pin out is different for audio. I have used no named brand from Amazon with no issues. The milage may very depending on the brand you purchase. Just look into other options. This is my opinion on this issue. P. S. You can thank apple for getting rid of the headphone jack. They just wanted to sell more Bluetooth headphones or lightning cables to boost their profits. Of course they will never admit that was their plan. Just think how long it took to adopt USB-C in their iPhones. Thank the EU for forcing their hand on that.
Worst decision ever, Lightning is so much more stable and convenient.
BTT I wanted to guide you to this article:
But it looks that sometimes even known working adapters are not functioning anymore:
But you can give it a try.
I think the situation was a disconnecting of the USB cable even if it’s still plugged into the phone. And I have to disagree with lightning cable due to way they rust if in a damp environment. Plus it couldn’t connect a hard drive/ SSD without a power source on the hardware itself. I have a raid 10 for redundantcy backups worked fine. But work in the field you always had to have a outlet to back up the thing onto a good storage drive. Otherwise if you trust cloud storage. You wouldn’t have to worry about it. All the hackers out there is a tough selling point. I don’t trust cloud storage one bit. At least type-c provides the power needed for short periods till the battery on your phone hits a certain limit. Thunderbolt 3 is a type-c spec that should have been implemented long ago. That’s why I would disagree. That’s my opinion on the outdated lightning connector.
Beside the list linked by Incanus, please have a look at above discussion as not all adapter work for various reasons.
I use the one I linked here Best USB-C to Audio Jack Adapter for FP4 - #80 by Lars_Hennig
This is working fine and also listed in the Guide article posted above. So the argument that you cannot charge while listening is not really valid.
And what does the 3.5mm jack help if there is not decent DAC inside the phone?
Well for a year it didn’t work for me. I am now discovering (my post has been moved) that it depends on which adapter we use, which is both a good and a bad surprise. Good because it means there is a way to do it, bad because since I don’t live in the EU I will have to buy random adapters until I find one that works, since there is no official documentation provided by Fairphone regarding what kind of adapters work and what kind of adapters don’t. It still would have been much more convenient for me to have an audio jack directly in the phone.
And if not, they should at least implement a function to force the sounds through usb-c for cases the phone won’t recognize the audio adapter by itself. This is really a waste of time, money, and worse: physical resources.
I don’t hesitate bashing Fairphone when they blunder, but this is definitely not their fault!
They simply can’t test every Chinese no-name adapter you can buy in your supermarket for compatibility. It’s logistically impossible, there are thousands, and new ones appear every day. Not to mention, how do you specify a no-name object among hundreds of similar no-name objects?
(Speaking of “cheap Chinese no-name adapters you can buy in your supermarket”, I bought a jack/USB combo adapter in a supermarket, a 15€ thingy, and it works perfectly. Dumb luck. :man_shrugging:)
