So, everytime I use my headphones on the FP3 I have to restart it afterwards, otherwise the normal audio output doesn’t work…
I have had this issue since I got the phone over a year ago, but was too lazy to dive into it until now…
What do you think, is it a software related problem, or does it make sense to replace the headphone jack?
Looking forward to hear from you
First look at topic
and continue there if it’s the same issue
Then check out
as it may effect a number of issues.
If you think those topics do not address your concerns you should contact support@fairphoene.com as your FP3 is still under a two year warranty.
Please also check if your FP3 has the latest software update.
system
Closed
5
