Alarm not starting if phone is off (FP6)
I used to turn off the phone when sleeping. All previous phones that I had (OnePlus, Samsung, ..) were waking up a few seconds before the alarm should start ringing and vibrating.
When I purchased an FP6, on the first morning I missed the train since I woke up later. I should have checked before, but for me “startup the phone with the alarm” was a standard behaviour.
Furthemore, from both a sustainability and a health points of view it is much better to turn off the phone while sleeping.
Is it there a way to fix this? I don’t want to root the phone. But if it is an OS issue, I think that Fairphone should really consider this feature.
Other similar thread, but very old: Alarm not starting if FP2 is off
As far I am aware, no way to operate the phone when it is turned off (the battery saver does not work either).
You may turn on bedtime schedules or put it in the airplane mode, but I realise it’s not what you wish for.
You may also submit a feature request using the official channels.
You were “lucky” to only have phones which supports that functionality.
In my past experience it was the opposite, with way more phones that did not support that functionality, that phones which support that.
My suggestion is to leave the phone in airplane mode.
I would not want this feature with my fairphone from a security point of view. As this would mean, that if I turn off my phone - its never really turned off. Cause something needs to power on the phone again - so more of a deep-sleep/different low-power kernel running all the time when “powered off”. :thinking:
Since you are concerned about security, I would suggest that you review this thread about missing security measures on the FP OS lock screen: Feature request: Disable control panel access when phone is locked
Where’s the security risk?
Well, it isn’t really turned off in your sense then, same as with a computer you just shut down without flipping the switch of the power supply or without disconnecting the power cable.
If you are this concerned, you should better take the battery out of your phone to make sure no component in the phone is powered anymore.
If the FP6 really can’t wake up for alarms, that may be the case now, but perhaps this could be enabled in software if there’s no hardware limitation to it.
This was the case with the FP3 afterall … couldn’t wake up for alarms initially (reference), can do it now (at least with /e/OS … Settings - Apps - Clock - Permissions - Additional permissions - Power Off Alarm - Allow/Don’t allow).
