To start with I also had the connexion drop out issue. It would connect with my cheapo beats flex, then a couple of seconds later drop out before connecting again and dropping out again. After a few cycles it would give up. I didn’t report it here as I managed to get around it. Firstly by clearing the bluetooth cache and deleting storage. If you want to try goto apps and notifications / see all apps ( in menu touch show system ) Then Bluetooth will show up in your app list. I forced stop before selecting ‘storage and cache’ and then cleared cache, deleted storage. Secondly I went to bluetooth app itself and clicked to ‘forget’ any previously connected devices I wanted to re-connect to. I re-paired and had no dropouts since.
Yes I am kicking myself too. When (if) a patch comes out to fix BT control, I will wait to see if they break anything more important before applying it.
On the subject of BT control, exactly 14 days after the only reply on my ticket (which followed me phoning them), I received what I assume was an robotic update to my ticket in the name of an (well-known on this forum) agent. It stated : 'We appreciate your patience on this. '. The update doesn’t mention the issue at all “this” is as close as it got. Still at least the robot was polite and instructed me to ‘Have a nice a nice day!’.
Sorry it didn’t work. The only other thing I did was in system / advanced / developer options. I changed AVRCP version to 1.4 from 1.5. I doubt that did anything but I left it. There are a few other option there you could play with but yeah, I expect you will have to wait for the patch.
Have you reported this problem to FP? I only reported the control issue, dropouts were a short lived problem for me so I only mentioned control.
I wish I was too young to remember Max Headroom but unfortunately I’m not and I do ;-(
I have the ‘no-control’ issue since the last update to build ‘8901.4.A.0016.6 release-keys’ on FP3. Connection is ok, music can be played alright, but no control from remote device. Tested on Skoda car stereo (2017), Sony BT speaker (SRS-X something) and Sony BT headphones (MDR-1000X). All of them worked before. On the car stereo, there used to be displayed the MP3 metadata and a time-bar, now just ‘Bluetooth Audio’ and the phone name.
I tried unpairing on both ends, rebooting phone, switching through all AVRCPs from 1.3-1.6. To no avail whatsoever.
BUT: I also noticed, that the remote control on my wired headphones have a bug now. They are Sony ear buds (3.5mm audio jack) with the typical button in one of the cables. When double-pressing, the player (BlackPlayer EX) used to skip to then next song. Now it skips two songs. I definitely didn’t update the player recently, nor the ear buds. I’m not sure, is the AVRCP also responsible for wired remote control or just for BT?
I’m new here, can someone tell me where to file a ticket?
Please note that your Community Forum account is not valid for Support requests (it’s a wholly different system), but I believe Support requests might be filed without an account, too.
@freddy3 In response to your ‘Topic’ The blue tooth issue has been looked at and as far as I can tell there is an update due.
However I don’t use bluetooth except between the FP3, Marley Speaker, Raspberry pi, Windows PC and and a solar charging system. No headphones or car stuff
Would you please be so kind and test a thing: When I’m calling someone via the multimedia system of my skoda, the phone always calls the same number twice at a given time resulting in an error when trying to make the connection. Does that work for you?
I tested calling someone via FP from the Skoda car stereo. On the first try it failed with some dial-up error and retried immediately, which succeeded. I tried the whole thing a couple more times. There all calls succeeded right away.
