Hey all, posting here because I’ve seen some similar posts (other apps stopping), but not this one, and the suggested solution doesn’t work.
System:
Open OS 17.06.04, installed after a clean reset due to the same problems everyone had when upgrading, on FP2.
Occurs when:
Open clock, tap onto globe icon at the bottom, which should normally allow the user to select other locations.
Suggested solution:
The suggestion usually given is to clear the rogue app’s cache by accessing Settings -> Apps -> All apps -> *Rogue app -> Clear cache (see here ).
Attempt:
1- Settings -> Apps -> Clock -> Storage, and from there, since “clear cache” was unresponsive, I hit “Clear data”.
2- Tried again to launch clock, tap globe. Same problem.
3- Restarted. *(which, since the reboot button was removed - why??? - now requires turning off, waiting, and then turning on.
4- Tried again, same as 2. Same problem.
Anyone have suggestions?
Cheers.
