Unable to lock bootloader
I recently bought an fairphone 4 and wanted to install a degoogled OS.
I decided to go with iode and followed the (sparse) instructions on this site:
[iodéOS installation - iodé]
All went (reasonably) well till i got to step 9 relocking the bootloader.
When relocking the bootloader following the instructions provided here:
[https://support.fairphone.com/hc/en-us/articles/4405858258961-FP4-Manage-the-bootloader]
After running fastboot flashing lock and confirming, i get the message that my image is corrupt and no longer able to boot. I can still get into the bootloader (now in a locked state) and am no longer able to start the OS…
running fastboot flashing unlock unlocks the bootloader and I’m able to reinstall iode, so at least i haven’t bricked anything (yet).
So at the moment i have a fairphone 4 with iode and unlocked bootloader
As i am a total smatphone noob, I’m not sure what to do at this point.
Is there a better tutorial available on how to relock the bootloader, or did i just follow the wrong instructions?
Welcome to the forum!
You’ve stumbled into a known problem, see here for example
I suggest you are very careful around re-locking the bootloader as this often seems to lead to bricked devices at the moment.
which version did you try?
20220121
20220123
20220126
@anon9231953
I tried 20220126
OK, i did it initially with 20220121 without problems
Maybe you give this one a try…
and then change the updater apk, to get beta updates. v2 Version
Hi
is this still the proposed action: to install an old version and then upgrade later? I tried version iode-2.4-20220407-FP4. And trying to lock the boot loader at the end I twice was in panic mode. Once when I first went into endless boot-loop after “fastboot flashing lock”. And the second time when I tried the forth or fifth time to get instead of the known “verified boot” warning but the error message “boot corrupt”…
By some other forum posts I was able to find “getvar all” showing these results
(bootloader) current-slot:b
(bootloader) has-slot:boot:yes
(bootloader) slot-retry-count:b:7
(bootloader) slot-unbootable:b:yes
(bootloader) slot-successful:b:yes
(bootloader) slot-retry-count:a:7
(bootloader) slot-unbootable:a:yes
(bootloader) slot-successful:a:no
(bootloader) slot-count:2
and having a “fastboot --set-active=a” at least I could reinstall again. To avoid any additional panic moment and in favor to start using my new phone I’d like to get this unlock/lock issue solved - any safe path
