TWRP 3.4.0-0 Released
There is a new version available for our FP2:
https://twrp.me/site/update/2020/06/24/twrp-3.4.0-0-released.html
Download:
https://eu.dl.twrp.me/FP2
I’m wondering, if this version is able to decrypt /data, can anyone test?
Did a quick check when the new version was mentioned over here, but … nope.
Lots of decryption stuff in the changelog, but doesn’t work for my encrypted /e/ Android 9 on the Fairphone 2 currently.
(Decryption works fine with /e/ Android 9 on my Fairphone 3, though.)
Decryption on FP2 would need to be fixed in the device-tree.
Maybe @z3ntu can take a look?
He did …
Sometimes things just don’t work out, it is how it is. Stuff can be complicated, and encryption support in TWRP is not guaranteed for a reason I guess.
It isn’t guaranteed, because there is no generic solution and it needs to be enabled on a per-device basis.
There are probably libs and services missing for getting it to work on FP2.
If he wants to tackle it again, he can contact me and I can try to help.
Is it necessary to update to make future updates of a running Lineage 17.1?
AFAIK, no you are fine using an older TWRP version.
The new TWRP 3.4.0-0 successfully decrypts Android 7 encryption, though (a kind of decryption that was broken since TWRP 3.3.0)
