Hallo,
I got a work sim card and want to use that for tethering when travelling. I never used tethering before and have by default everything going over the other sim card.
To get it working in the first place, I had to reboot after configuring the work sim for data communication. Then when I enable usb tethering I can access webpages on the laptop. Then I tried to connect the work vpn and the connection seemed to still be there but did not work anymore: webpages didn’t load anymore (public and internal), teams and outlook lost connection etc. The moment I disconnect the vpn it works again.
When trying this on my private sim, it does work, when trying the work sim only in my fp3 it also works.
It feels like there is somewhere a setting misconfigured when both sims are in use, but I have no clue where.
If I switch both sims to the brand new samsung work provided I can use vpn over tethering over both sims.
Does anybody have any suggestion what I can still try to make this work on my fp3? I do not want to walk around with 2 phones or switch to the work phone.
