Speaker, microphone don't work after i pulled out my headphones
So the issue is still there even after the recent update, only restart solves it. No sound after plugging in wired headphones after plugging them out, and when you take them out again or try to wiggle the headphone jack then press play and then pause you get a hissing/static sound.
After latest update it happened like this:
  1. Plug headset, listen to music
  2. Unplug while music was on => No sound
  3. Plug headset again => sound in headset
Repeated a good few times, starting and stopping music app, only restarting phone got sound back to speakers.
This app may serve as a workaround:
(Removed link to com.gembatechnosoftt.headset_testt)
Not sure yet cause issue has not happened in a while, but it is the best option I found in play store.
Nope, it just made it worse. I heard that clicking noise for the first time ever, and behaviour is less predictable with that app running. Uninstalled it.
I feel you. Its so embarrassing that FP has not fixed this with their updates.
Yesterday I got an email notification for my support ticket that I had raised earlier this year.
The email says that the update A.0120 “brought significant improvements” regarding my issue. I had updated to that version as soon as it was released, and in fact I didn’t have that problem in a very long time. Not sure if that is related to my habit, of first stopping playback before unplugging the headphones. I’ll try to just unplug in the future and see if the problem still persists.
I had it once or twice but not recently so good news here, not sure if patched out or not.
I used to have this issue, especially with phone calls, but it has been solved on my phone for a while. Not sure if it was solved with A.0120 or an earlier update.
Excuse moi, je comprend francais, mais c’est dificile pour moi a ecrir.
Je continue en anglais.
I found the problem is the phone is not switching between headset and external speaker/microphone. When the headset is plugged in when you are being called or when you make a call, there is no problem.
When you have used your headset (listening to music or something) and then unplug the headset, the problem will start and you will not hear or be able to speak to the other person.
Reboot works. Until you use your headset again…
I don’t have a solution yet, sorry.
I’ve moved your topic here as your problem sounds very similar to what’s written in this topic. Please check the posts above.
