You may want to have a look at the FP2 issue tracker:
And many other companies have their projects running on Github.
At least the open builds of a Fairphone Android ROM should get public issue trackers. They are a possibility to interact directly with the users who experience issues, a community forum cannot do this…
The key difference, I think, is that the FP2 isn’t being sold anymore… I agree that it makes eminent sense, but I understand that from a vendor’s perspective there are reasons against it. And yes, other companies do this, but I know of no example in the smartphone market, which is the only relevant comparison from FP’s perspective. Do you?
Oh dear, that sounds not good. Display is going dark and callers are not shown anymore on Vodafone Germany.
Meanwhile the update is available to me, but I did not yet install it because of the bugs mentioned here - I am on Vodefone Germany, too.
If this is the solution for you, then you are lucky! For me it would be not a solution, because the 2G bandwidth is too low for most apps to operate. And 3G is switched off here in Germany already.
For all of you, who already updated, I wish good luck for a very soon bugfix!
And for myself I wish the same, as I really want to update to get the August security patches - but without the bugs.
I got the same Problem “unknown” caller. Only Workaround is to change to 2G AND disable WiFi Calling. Both makes my Phone un-usable, which is my phone for work. When this will be fixed?
Hi @til Welcome to the forum. Let’s hope Fairphone sees your query, they do poke their nose in occasionally, but if you want an answer you could email support\at|fairphone …
