Reichlich spät, da war das S5 dank fehlender Sicherheitsupdates schon seit Jahren unsicher. Ein Telefon aber als unbrauchbar zu bezeichnen, wegen eines Fehlers bei einem Provider, den man zudem noch umgehen kann ist dagegen schon ein wenig harsch.
And this answer comes after two months ?? In my time as a software developer, customers were treated differently. The FP3 + was my first and last model from Fairphone.
Leider kann ich den Work-a-round nicht nutzen, da wie geschrieben hier in weiten Bereichen das 3G schon abgeschaltet ist. Wenn ich mit 2G telefonieren möchte, hole ich mein altes Nokia wieder raus. Sicherheitsupdates hin oder her, es muss ganz einfach zum telefonieren geeignet sein.
Amazing… lets roll out the update in france first. Not in the country wich is heavyly affected by the unknown caller bug since two months… lets do exactly that!
you said: This update will include a fix for the Caller ID issue …
I`m still very disapointed!
There ist still no update and no solution.
Did I miss it?
regards
Thomas
Usually, people add a print screen of the update. You can see that it is not the case here so I find strange this information especially because nobody else said the same, not even in France
Well, for that to happen, you need to have a FP3, be using the standard OS, have Sosh as your operator (OK maybe Orange as well, who knows?), be interested in Android updates, be familiar with the Forum and know enough of the etiquette to leave a screenshot. What’s the probability?
And yes, two people in the other thread have notified having received the update.
Hi, just to confirm it , I could manually find the update. As you can see , security patch level from October the 5th. The original update of this thread was not available for me ( Sosh is my provider). So I had no unknown caller issue and I do not have it after updating at least I had only calls from my contacts but no issue so far
