AnnaHa
February 12, 2022, 4:05pm
1
Hi!
The microphone of my FP2 is broken and I am looking for a new bottom module. Anyone who can help out?
What product(s) are you looking for?
FP2 bottom module
(Once you have found the product you were looking for, please add [FOUND] in front of the topic title or ask one of the community moderators to do it for you)
Where would it/they need to be shipped (country or city)?
Other, remarks:
NB: If you are interested and want to send a direct message, please check #how-to-dm .
Be aware, that cross-border shipment of batteries outside a phone is virtually impossible for individuals .
Hi whilst you wait for a source you may like to consider a shop or DIY repair.
As fairphone angel (in Berlin) I have a lot of support cases with nonfunctional microphones in the bottom modul. A lot of users have minimum the 2nd, often the 3rd bottom module. Mostly easily changed by Fairphone support in warranty.
But there is a lot of waste (I collect old faulty modules and send them back for recycling).
So my questions:
Did anyone successfully repaired the microphone inside the bottom module by soldering a new smd microphone?
What’s the reason for the highly rate of f…
This topic also has info about mic repair
@JohnHughes (thanks again) send me two broken bottom Modules some days ago. This one has a defekt µUSB port.
After disassembling I took a picture with a microscope camera and found some solder cracks. Barely to see without magnification. Two cracks at the shield contacts that I am not too worry about, but also one at contact 5. I am sure that was a slack joint. Some serious force must be acted to the Port.
I will try to resolder the joints and hope the bottom module will be able to do its work…
system
Closed
February 19, 2022, 5:53pm
3
