Please note, the Part # does not really tell you much about the MP oft the Camera. Not sure if there are REC02 with 2 MP, but there are def. REC01 with 5MP.
This depends on the OS that is installed. With FPOS you can just look it up in the settings under about the phone and hardware. Else you could see in the settings of the camera app
I actually own to FP2 both with 5MP top module, 1 is REC02 the other is REC01
But this was not my question: If you have two modules on your table, both with part # FP-REC01 - how do you see which is the 2MP and which is the 5 MP.
After all the posts here it seems that you can’t see it - you have to put it in the FP2 at first and look in the settings.
OK you’re telling me again that I’m not paying enough attention, I suppose the one in the shop is unavailable but on my viewing there is no indication that it is not available.
Ah! when I try to actually buy I only see the 2Mpx that must be what you mean ~ I’m getting there.
version 2 is now out of stock,
It’s a way a child learns ~ they repeat what they hear and adapt
The only problem when you buy it second hand… if you bought a “5MP” and you only see it in the settings of FP2 that you got a “2MP” - you have a small problem…
