"SD-Karte wird von diesem Gerät nicht unterstützt" 🇩🇪 🇬🇧
SD-Card not supported by this device (FP2) - offers formatting, but stops at 20%.
…i have the same problem…(and the SD-Card is working with my Laptop)
Hi, for both of you: please specify which type of SD card you are using. Maybe it’s an issue with a specific manufacturer.
Pleas also take a read here and here.
It may in both cases be due to a poor performance for which the phone will not accept the sd card as internal storage which would add up with the built in storage.
