If the phone is still unstuck after having wiped the battery for more than an hour, is there any alternative that can be tried to start it?
In my case, the phone stopped working and only made some flashes of the screen in blue, but now it does not do …
What you are describing sound very much like a broken power button (screen flashing) (repair information) and a drained battery in result.
Can you charge your battery? (Does the red LED light up, when you connect your phone to the charger?)
The battery loads, but the LED is only lit intermittently. After many attempts, I got the Android robot appearing, but not the menu of options …
Try to get your power button repaired at a #localrepairshop.
