Render checkboxes
They’re not currently rendered.
I’m not sure what you are getting at the > Details relate to screen brightness not a forum GUI
If you are talking about the Discourse UI where do you expect to see a [checkbox]
If you were to create a poll you would get options for checking but there are circles not boxes
@anon9989719,
That’s the origin of the request. It provided additional demonstration of a use-case for it.
You don’t seem familiar with Markdown. The .md code
should render a checkbox. That was why I used in the above example.
I don’t see the relevance.
This makes it sound like a bug or shortcoming, but as your link shows, this is a plugin, so it’s optional, so it simply doesn’t seem to be installed here yet.
But as it is an official plugin, the question would be: why not install it?
Yes I see that :slight_smile:
There’s lot of markdown and html that do not render, it changes over the years :person_shrugging:
I was wondering why you wanted the check box
You may like to see
Because every additional plugin will probably bring more administration work and possible problems (although I agree that official plugins should be better here than inofficial ones).
So I’d just vote for installing “relevant” plugins. And even after reading the usage example I honestly still can’t see this as relevant…
Maybe this is what you were hoping for
