Reboots after A15 upgrade
Same here! Every morning it starts up sometimes even twice when I open the phone… glad I’m not the only one :slightly_smiling_face:
But I don’t want to deactivate all these functions…
What is KISS launcher?.
Oh…. Aber ich spreche kein Deutsch, das finde ich ziemlich schwierig.(Google translate)
Therefore I opened a seperate topic for you. This is always possible, we just dont mix all languages in 1 topic, unless the topic started decides to write a topic in dual language.
Well I suppose we could communicatie with translate …. I do that very often.
Also, It makes the topics very fractured
Well you could have done it and post in german. However we ofzen have the same issue discussed in different languages that works well for years. So kindly accept thats how the forum is working.
Another Launcher like e.g. Kiss is another App you can download
Okay
But what on earth is Launcher and what on earth is KISS???
Launcher = first screen you see on your phone after starting (startscherm).
KISS Launcher is another type.
Normally Fairphone uses the Launcher Quickstep.
But that one isn’t function well with some users.
That’s why the workaround by using a different launcher like KISS Launcher.
It’s an app you can find in the Play store of Google
I actually didn’t know about this … let’s not make a problem out of It
I actually don’t feel like doing all that. I just want My Fairphone to function as it usually did … Ik zoek not happen after an update I think is that strange?
Hello there I have the reboot issues as well, after Android 15 update my fp4 reboots randomly, and the last two days it rebooted right at the time when the alarm was set, leading to the alarm not working. I even get a system message telling me the alarm did not Funktion property.
Buongiorno, anch’io problemi dopo l’aggiornamento android 15 con continuo riavvio del Fairphone 4. Succede spesso quando accendo lo schermo.
Ho scaricato Kiss Launcher, ma cosa devo fare poi?
Non sono utente esperto quindi non ho capito cosa devo fare. Grazie
Good morning, I am also experiencing problems after the Android 15 update, with my Fairphone 4 constantly restarting. It often happens when I turn on the screen.
I downloaded Kiss Launcher, but what should I do next?
I am not an expert user, so I don’t understand what I need to do. Thank you.
Hi and welcome. I moved your post here, there is also a german topic. So far no real pattern was detected
Good Morning. I also have this problem ever since the A15 update. It has rebooted twice in rapid succession at around the same time each morning (~07:10 GMT). It’s a little disconcerting, to say the least,
(FWIW I’m using the stock launcher).
Yes, same here. Two times one after another ….
As I have the phone on English, I don’t know the Italian words.
But I hope you can understand what you have to do.
Go to the app Settings
Type in the line Search the word launcher
Tap on Default home app
Choose KISS
And the phone changes to the KISS launcher
Restart your phone.
Dato che il mio telefono è impostato in inglese, non conosco le parole in italiano.
Ma spero che tu riesca a capire cosa devi fare.
Vai alle impostazioni dell’app.
Digita nella riga “Cerca la parola launcher”.
Tocca “App home predefinita”.
Scegli KISS.
Il telefono passerà al launcher KISS.
Riavvia il telefono.
Translated with Deepl.com
Same here in Germany . I punched in all data to open a support ticket but failed in the end: “Please contact the online support…” :frowning:
Thanks but …..
So now I have to search for ALL my apps. They aren’t on the screen anymore…. Also can’t change the language…. :slightly_frowning_face: I don’t like this AT ALL!!
I think fairphone has to do something about this isue…
When you change the default home app you have to set up the apps you want on your screen again.
If you change to Quickstep again, all your apps you had on your screen are back.
