Noise, when micro should be on
When calling or being called the other end of the line only hears noise and then silence. When self test performed both micros (1+2) perform the same noise. Bottom module allready exchangenged, but no improvement.
Is it a hardweare problem or soft ware? Can it be fixed?
Thank you
Rainer
Welcome to the forum.
Could you indicate your OS version and which phone app you are using. For the OS go to Settings > About phone > Build number.
Did this problem occur after some event?
For tests a local Fairphone Angel may be able to help. Check out the map to see if there’s one near you.
Hello, I found this post because I am having the same issue. I have replaced both the top and bottom modules, and I have factory reset the phone. I am using Android version 13 and the build number is 6.A.039.7
Sorry for the delay in replying.
@HappyCakeDoll Did your problem appear after an event that you can identify such as an OS or app update?
Have you performed a self-test (for the hardware)?
Are you able to make voice or other sound recordings normally and without noise?
