I cannot find the usual spec for this mobile phone anywhere . What is the memory for these phones? Anything less than 64gb is not on for me
Come on now … Specs
Edit: If you mean the supported SD card size …
The technical specs don’t mention a limit, only “MicroSD Support: SDHC, SDXC, UHS”.
This support article mentions a limit of 64 GB, but in practice that doesn’t apply, I use 128 GB myself (with LineageOS) without problems so far. Have a look in the topic @urs_lesse linked to at what other users use, only some particular cards seem to generate problems.
Also …
BertG
April 27, 2018, 11:21pm
3
May I ask, why that would be?
You can insert MicroSD-cards of at least up to 256 GB (working in my phone).
I would expect even the larger ones should be working.
Here’s a list of cards “tested” by users:
ATTENTION!!
This wiki is just a list by FP2-users.
It is there to share experience with MicroSD cards.
It is nothing official by Fairphone.
Fairphone does not sell any of these cards.
Which MicroSD cards do work and which do not? Fairphone does not have the capacity to test MicroSD cards and is not in a position to endorse the use of brands or types of cards. So I hope that the community can help to make a nice list of good MicroSD cards.
Although Fairphone is said to support MicroSD card…
And you can even use those cards formated as internal memory. Although I would not advise to do so, according to some reports from this forum, like this one:
Hi there,
I m getting grey hair here! Having issues with my SD card. Its is formatted as internal memory, which seemed a handy extension for my phone memory. I am doubting that by now though.
Problem is as follows:
FP2 stopped being able to write to the card, I couldnt take & save pictures, see/download the pics on whatsapp, install new apps etc. After a reboot and emptying the caches of Kamera/WhatsApp i.e. they would work for a few minutes until i got a message stating “couldnt write to car…
