Hi danxuliu, ist there a TWRP for fairphone 1 with unified storage layout ? i have a broken fp1U and would like to create a backup. Backup to sdcard in original recovery does not work, because its 6GB data, and vfat only allows 4GB-Files.
Sorry @amar, I have worked only on the version shown here with the original storage layout. I do not know if someone else developed a TWRP version with the unified storage layout (maybe @jftr for the official KitKat upgrade?).
Yes, TWRP should be able to handle that, as it splits larger backups in several files (well, I suppose that you already knew it, but just in case
You could probably use ClockworkMod, maybe @Stefan can explain how.
PS: I moved this discussion to a new topic because now it doesnāt have much to do with the original topic anymore.
Yes, the recovery.img can be found here:
https://forum.fairphone.com/t/fp1-u-link-to-latest-cwm-recovery-version/6418/11?u=stefan
Note that there is no fastboot on FP1, so youāall have to flash the image using adb shell: https://forum.xda-developers.com/wiki/Fairphone_Fairphone/Flashing_Guide
This is interesting. Are you sure?
I havenāt used it, yet, but I would assume that (almost) every Android phone has fastboot.
Thanks for your quick answers:
i tried to flush recovery.img with fastboot:
sending ārecoveryā (5688 KB)ā¦
OKAY [ 0.218s]
writing ārecoveryāā¦
FAILED (remote:
partition ārecoveryā not support flash)
finished. total time: 0.237s
Didnt work.
Is there a way to put the recovery.img into a .ZIP-file so i can put it with adb sideload ?
The only command i can run with adb is sideload.
The easiest way would be to boot your phone and flash it from there. It should even work when youāre stuck in a boot loop. But you need to have your phone and your PC already set up, before. (If youāve successfully used adb before this should do.)
Otherwise you could try flashing a specific partition with proprietary Mediatek tools and your bootloader. (Please be careful!)
Thanks for your tip.
I could recover the images (which was the only important data) with the sp flash tool. I used the
Readback option to read the memory to a file, then i run photorec on that file to recover the images && movies.
Steps on linux:
- Download sp flash tool (wget http://mtk2000.ucoz.ru/bbkl/SP_Flash_Tool_Linux_v5.1648.rar)
- Extract sp flash tool (untar x ./SP_Flash_Tool_Linux_v5.1648.rar) password is mtk2000
- Download fairphone binaries http://storage.googleapis.com/fairphone-updates/FP1-Fairphone_OS_v1_8_7_Image_2015081400.zip
- Extract fairphone binaries (unzip FP1-Fairphone_OS_v1_8_7_Image_2015081400.zip)
- start flash tool as root (cd SP_Flash_Tool_Linux_v5.1648 && sudo ./flash_tool.sh)
- Choose scatter file in FP1-Fairphone_OS_v1_8_7_Image_2015081400 folder (MT6589_Android_scatter_emmc.txt)
- Choose Readback Tab (Filename: 4G-ROM.img Start Addr 0x0000000049d80000 Length: 0x0000000100000000)
and click Readback.
Connect your phone to the usb with the volume down pressed. sp tools starts to read your phone within seconds. This gives you a 4GB file - run photorec on the file (sudo apt install testdisk && photorec 4G-ROM.img
Your images and movies are restored into a directory. - Copy all images that are bigger than 100kB to a special directory
(find . -iname ā*.jpgā -size +100k -exec cp {} /home/user/pictures_over_100k ; ) - Drink beer
greetings
amar
Iām hooking in @werner_noebauer (Is it ok that I closed your topic?). He has the same issue:
Itās great to hear that this actually works.
At the time I was doing this it didnāt manage to connect to my phone using Linux (I think; or I was worried about running this software as root). I set up a VM with Windows 10 inside and used this.
BTW: In which way is your phone broken?
Perhaps itāll work again if you reflash it?
Itās no my phone, itās FP2 but afaik it does not even react to the power buttonā¦
If itās a FP2, this will not work. This is related to the Mediatek chipset.
Your topic is in #fairphone-help and not in #fairphone2helpā¦
Hi Stefan,
I thought it is a FP1 so I started here⦠It is the phone we were talking about in our last meeting
This thread can be closed.
I didnāt remember if it was a FP1 or FP2.
Iāve moved your topic to the appropriate category.
