It’s been many month that my FP2 loose the GSM network quite in all my call. I succeed in having calls but it’s embarrassing.
I already verified my SIM slot, my network provider. I check visually the connection of the antenna cable…
The only thing I read is to backup all the phone and try to reinitialise it.
I would like to avoid this solution because I can’t skip my phone use for my job and for the moment it works badly but it works :-))
How old is your SIM card and who is your provider?
My SIM is 1 year old and when I changed it I already have the same problem.
My provider is SFR in France.
What happens if you switch your phone to 3G?
sorry for the delay. Nothing better when I switch on 3G.
It could be your SIM. Try it with a new SIM.
Thanks for your answer,
In fact, it works very much better in 3G !! The conversations are not cutting
Just, very often, when someone try to reach me, the phone doesn’t ring and I only receive a call notification by sms.
Any idea of the problem ?
Toggle flight mode on/off when you have lost the network connection.
And have a look at this thread loss of network connection.
Thanks,
In reading all thé forum comments, I understand that there ils no solution. That’s strange.
And turning togle flight on off is not a solution for me because thé problem ils that i’m loosing calls.
So switching to 3G is the best oprion for you.
Still a new SIM could work better and of course the coverage of your provider could alsibe a part of the problem.
