Hi
I have very similar problems. At a lot of places where my colleges with the same provider have good reception my phone has not network.
Fabian
Hi
Fabian
Hi all
I’ve had this problem for a few weeks now. I lose connection all the time - I seem to be able to reproduce it in one specific situation, but it happens lots of other times too (when making calls, when checking facebook, etc).
Unfortunately I still have a very serious problem with random reboots (been going for 3 months+) so have requested a replacement.
I am running 1.7.0. I can reproduce the loss of network by opening the guardian app, then pulling down to refresh the information, at which point the network instantly disappears. It happened when I was using one sim. It still happens now when I use two sims - network on both sims disappears immediately that I try to refresh.
Not sure if this is helpful, but I guess it might be useful to know that others are experiencing similar issues.
Paul
This sounds like the problem I’ve been experiencing the last few weeks; when i am away from my wifi connection I don’t receive any app messages. When I come back to my home wifi, I suddenly get messages from the past hours all at once. What’s going on??
I got a new sim card and today also got it reset by my provider, but still didn’t get messages when I was just out.
Feeling frustrated!
Elise
Two quick things:
This doesn’t necessarily mean that the phone is losing connection to the mobile network. If you see that the reception icon is empty, or has a cross in it, then it could be if that state persists for a long time.
I’m assuming you’re referring to WhatsApp/Signal messages, rather than MMS.
Have you tested whether cellular data works? (e.g. can you visit websites away from your wifi?)
If it does, have you tried opening the app when you’re away? If you do get the messages away from wifi when you open the app, then background data is probably restricted for that or all apps (see here).
Quite right Johannes, particularly about checking with support first.
Also, I’d like to add that it took me a while to ask but when I finally did, I had an answer within a few days.
Just make sure you follow the instructions properly to contact Fairphone support. I admit it is a bit of a complicated process but when done properly, it does work !
check this out FP2 dropping calls and make sure you have done everything right in the ticket opening process…
Hi
My FP2 worked perfectly the first three months. Suddenly, from one day to the other it couldn’t find the connection anymore. Since then the battery looses the power within 2-3 hours.
-> When I want to check my messages I have to turn off the simcard and turn it on again. Like that, sometimes my phone has enough time to download missed messages.
-> To make a phonecall, sometimes it helps when I put the connection on manually (on my own network), but usually the phone needs lots of tries and lots of time to find the own network.
-> Next step: I send my phone back and hope to get a new one within a few days (for 500 Euro I expect a serious support!!!)
I went through this thread. Up to now I haven’t experienced dropped calls. However, my impression is that the reception with my FP2 is a bit poorer than with other phones (I know, there a thousand other possible reasons for this).
Still, I bought a torx screwdriver (T5, if you want to know) to check the antenna connectors. The connector in the lower left corner of the phone was firmly attached to the circuit board (I could rotate it by some degrees without loosening it). The other one, just above the battery pins, was also connected, but I could easily remove it from the board with a tweezer. In turn, I could reconnect it as easily. As I don’t have any experience with such things, I cannot tell, if this connection is sufficient or if this may be the cause of my problems.
At least, after reassembling all the parts, my phone is up and running again ![]()
Hi all,
In my case with last OS update 1.7.1, I realised that after several minutes or hours with Wifi connected, when I switch off Wifi in order to get back to be 3G/4G connection, I get without internet until I make the flight mode trick(on/off) or I manually select the network of my internet provider.
I guess that this particular issue could be related to a SW issue.
I hope this could be usefull for developers.
Just to let you know, what happened to my problem:
I eventually filed a support case. After some e-mails going back and forth to track down the error, I was asked to send my phone back for further investigation and repair. In the end, I was provided with a new phone
The new phone is running flawlessly since the first day.
Finally! Something that worked for me!
(Operator: free mobile in France)
On FP2 FPOS, I have the same problem with data 3G or 4G. The airplane doesn’t solve the problem for me, only a reboot
I have the latest version of th OS (16.12)
Any idea is welcome
