LineageOS 14.1 with OTA updates for FP2
Are you sure you are using the latest update? I am wondering about it because you posted about an OTA update a few hours before the build with the fixes was available. Did you do another OTA update afterwards?
I was wondering too.
I postet 26.06.2017 at 6:20 but the time stamp of the file is 08:25.
The build date in my phone settings shows 25.06.2017 21:01.
The build date on my phone is
Your Build date is older than the date of your Kernel version. :upside_down:
This was a build that didn’t have all the needed fixes: The newest one has build number: c55f5cafd9.
You can OTA update to get this one.
Thank you all for your support.
It must have been as @snevas said, an intermediate update that got drawn back. I was too quick :slight_smile:
Now I have downloaded and installed the latest update manually.
My fm radio now works! :+1:
Still I do not understand why the Build date (Jun 26 08:25:45 UTC 2017) is older than the date of the Kernel version (Jun 26 08:48:59 UTC 2017).
@snevas may correct me if I am wrong, but I think the build date marks the start of the build process, which lasted 4 hr 42 min. The kernel was then built during this time.
I also have build number 4406f0c793, but the OTA updater keeps telling me that there is no newer version available?
Are you connected to wifi (there’s a setting that it only checks when connected to wifi)?
I am.
shutting down the updater-app and emptying cache didn’t help either.
I have a question regarding the update. I downloaded the upload (to where, I don’t know) and pressed install. It rebooted into TWRP
 and then? :confused: What do I do? Probably install the .img or .zip, but I didn’t know where it was.
Did you flash the TWRP with OTA fix as described in the topicstart (?) :
https://fp2.joutubes.nl/builds/full/TWRP_3.1.1-0-ota-fix.img
nope, just the normal TWRP update. S****. Just flashing the fix probably won’t work
 I’ll have to reset everything again. :sweat:
Don’t be negative, you only need to flash the TWRP image with the fix (you can do this from TWRP itself after downloading the image), and retry the update with the Updater, :slight_smile:
The problem with TWRP is that it doesn’t know where to locate the update. Everything else in your setup is fine, :wink:
Hello everyone! I’m craving to install the LOS but I didn’t get how to install use OTA build from weareFairPhone
 Sorry for the dumb question.
Should I just flash the last build that I see at the top of this post with twrp or I have to do something else?
I have FairPhone open 16.10. , I never updated further because I have xposed installed and I read somewhere that updating the software would have caused me a bootloop
So should I first uninstall xposed, update the FP open, and then flash the LOS with twrp?
I’ve moved @demetrio’s post here, so his reference was originally to a different build. Apologies for any confusion, and apologies for moving the post to the wrong place initially.
Just start at:
You’ll lose all of your installed apps / data, so make backups!
No need to do anything beforehand like uninstalling Xposed as this will be overwritten.
I am having some problem in installing this OTA fix of TWRP through Fastboot.
I don’t understand the guide of z3ntu. More specifically I don’t get the very first three lines
 What do I have to install?
Can I have an extra help?
  1. download the TWRP with OTA fix, modem.zip and lineage build mentioned and save it on your internal memory or sd card (where you can find it)
  2. then go into TWRP mode (Vol.-Up+Power-Button).
  3. There Choose menu “install”, then “Install Image” and choose the file you donwloaded. Then “Recovery” and swipe to flash.
  4. You will land in TWRP again. Then choose menu “Wipe” and swipe to reset the phone (please remeber to do a backup of your apps and pictures/videos before!!!)
  5. Again in TWRP choose “Install” and select the modem.zip and lineage.zip and install.
