Internet, phone calls, text messages issues - Wind Italy
I bought the fp6 less than a week ago, and I am experiencing an annoying issue but Maybe it’s a little thing I can solve with your advice.
I have a physical SIM card, it worked on the old phone, but here it seems to work oddly now. sometimes yes and sometimes it does not work properly.
I can make phone calls and I have issues in receiving phone calls, sometimes the phone does not ring and the caller is said I am not available.
I don’t receive text messages, but sometimes only after hours.
With WiFi internet works, without it it goes on and off.
So I assume it’s a SIM card problem. I already restarted the phone, I also reset it to fabric settings and started over but it didn’t solve the problem.
I cleaned the SIM card, placed it more carefully, I contacted my network provider but it’s all fine on their end.
The problem also is temporarily solved if I switch off and on the device. (So I tried to clean up the cache but it didn’t work either)
So I ended up opening a ticket via myfp app. I know it might take some time but this is making the overall experience very frustrating as I am travelling a lot lately and I kinda need to have a reliable phone. Is there any other test or attempt I can make to see if it’s a setting/update thing?
Thanks to everyone
would agree how old is the SIM card? I suggest to talk to your provider again and get a new one.
Not sure how old, but a fair bit.
I don’t get why it works on the old device and not here, though
Btw replacing it has a cost, not impressive cost but it has one.
So I didn’t want to end up in the situation I bought a new SIM card or an esim and the problem is still there because of the phone malfunctioning.
so how old is it? I had the issue in the past on my FP2 that I could call people however incoming calls didnt work. The SIM worked without issues on my IPhone. Replacing it I got rid of all issues. I’m surprised that replacing a faulty SIM comes with costs…waiting for FP support can take time (weeks) so maybe borrow a SIM from someone else to see what happens.
Thanks for replying,
I’ll try to put my SIM on a different phone and I’ll try a different SIM on my fairphone.
So it can reveal if it’s the SIM card or the phone causing this problems
Hello, I recently had a problem with my new FP6 and the sim card.
It worked fine for six weeks, then one day the phone would not not connect to my provider’s service. The sim card was recognised by the phone, I had to put my PIN # in to unlock it, but no telephone connection. The WIFI worked.
We inserted the sim card in my husband’s FP6, the card was not the problem. His sim card in my FP6, no recognition of the card at all. Very frustrating with a quality phone that was new.
It was of course under warranty. It was sent to be either repaired or replaced and in the end, it was replaced with an identical FP6. It could not be repaired, the fault was in the sim card recognition failing in the phone. I purchased it from the company Orange, which is also my phone service provider, they took it in charge.
Unlike you for you, my FP6 did not work off and on before failing completely, but otherwise it sounds similar. So potential for failure could be a concern.
Thanks for the answers, I confirm it must be the phone.
SIM card changed (paying ofc the network provider) but the problems are still there.
I checked the signal power and it’s often below -90 dBm. So I think it’s the smartphone antenna. So… support will answer sooner or later I hope.
I got my new FP6 and it would not recognise / work with the simcard that’s been fine for a couple of years in my old phone.
I ended up doing an eSim from my mobile provider and that worked.
Have signal and function as expected.
Have you tried an eSim?
I left the physical simcard in and now have two icon indicators showing the mobile network status.
The first one, to the left of the WiFi calling enabled indicator has ! by it. Not working.
The 2nd one to the right of the WiFi calling enabled indicator shows signal strength working.
I will try removing the physical simcard and see if that removes the non working indicator.
Sorry, I already paid the new SIM card, I expect a new phone paid the full price would work as expected, not with paid work arounds.
I’ll wait support answers. But this getting some time now.
Can you test a SIM from another provider? Do you see any reception or nothing at all? Whats your provider and country? Are the APNs correct? Do you have VoLTE enabled? Do you have 5G enabled?
The provider is “wind” Italy.
I tried another provider it worked but it’s hard to tell since the issues goes on and off. When I restart the phone or re insert the SIM card it suddenly works for an hour or less then the same issues.
I moved in different locations in the country and the issues stayed so I assume is not a single area facing provider’s problems.
5g is enabled, the apns are the same of the old settings on the old phone (it worked there)
Can you test without 5G?
I added country and provider to the title…
Also there is a general topic related to VoLTE in Italy. As my italian is rather limited, I dont know whats overall discussed there, but maybe you will find some hints if it might be rather provider related.
Unfortunately I think the topic is not relevant to my experience with the issues.
I can make phone calls the quality is good, but often I can’t receive phone calls, receive text messages or using internet (it goes on and off making the experience of reading any site or loading or uploading any message very poor and slow)
Can you please test without 5G as @yvmuell asked?
5G and VoLTE are separate matters.
First of all thanks again everyone for the answers and the time dedicated to this topic. Sure I’ll try. What does it mean if setting 4g makes the issues go away?
Sorry, I am not too much into techs
It means that the combination of your Fairphone and the 5G of your provider makes the phone less useable. And that choosing for 4G the solution is that you want at this moment.
It’s always possible that in the future 5G will work.
So far so good.
Looks like 4g+ is doing ok but as I said I’ll monitor the situation in the following days since issues were going on and off suddenly.
Anyway, reading the Italian thread it was posted above I find a bit unjust to not signal some of this kind of problems using fairphone in some countries.
If I understood correctly there is a difficulty on making available 5g in Italy with all the network providers while they are working on it it’s already available in the Netherlands and Germany since there is a bigger market for them there.
Maybe it should be a note on the site since the product is the same while performances may vary depending on countries.
I also add to the suggestion about disabling 5G.
I don’t know why but disabling 5G solved a couple of problem both on my FP6 and my company phone (Samsung).
And the most interesting thing is that I use COOPVoce as an operator and they don’t have a 5G offer so the 5G option shouldn’t impact on the way the phone works.
Neverthless, when “Preferred network type” is set to “5G/4G/3G/2G” my internet connection is “4G” (upper right icon) and when i change it to “4G/3G/2G” my internet connection is “4G+”.
So it’s worth giving it a try…
Ciao,
Max
Well, I got by FP6 last Friday.
After the physical sim problems and eSim, i was getting what I thought was a normal signal at home.
We are out in the country so the signal is a bit patchy.
I work from home and didn’t need to travel away from WiFi until today..
Absolutely no signal where my old phone would have had 4G.
Wife’s phone had 4G (same operator). Up at Heathrow I did get 3G! Wife’s phone had 5G.
Back in the car no signal again!
Very strange. Have to look into it!
Operator data looks normal. They think all is normal.
I will get a new physical SIM from my operator and see.
Otherwise it’s going straight back.
Happy to report after erasing the 1st eSim, then phone off / on cycle, getting a new eSim, installing etc, phone off and on cycle again, all is working just fine!
Can make and receive calls / have 4 / 5G where available and everything is working just fine.
Generally I’m liking my FP6 very much!
Sorry for polluting this thread with my woes.
