In search of a FP3/3+ camera module
FP3 camera module 12 or 48mp
During a festive night out I dropped my phone and ever since the main camera is not responsive, rest of the phone works perfectly still. I tried reconnecting the module today but that didn’t work either.
I am looking for a FP3 camera module (12 or 48 mp). I am willing to pay for the module and for shipping.
Greetings from a Fairphone enthousiast since 2014
Shipping would be to Belgium, Antwerp
Just to make sure – have you checked the connection of both ends of the camera module connector cable? One of these is hidden under the metal shield and has gotten disconnected (from the core module/motherboard) some times in other users’ FP3 devices.
Didn’t know that was possible, will try reconnecting the one under the metal shield
now in stead of black in the camera app, the app just won’t launch, other camera app only works with selfie cam. I think I made the problem worse :frowning: So I probably did something wrong with the connector.
If you find it hard to access the other end of the connector, you can remove the metal shield with a Torx T5 screwdriver to get free access to it:
One more suggestion: For pure testing, you don’t need to screw all 13 display screws back in every time, it’s usually enough to just make sure that the display properly “clicks in” at all its edges.
Did you try to clean the contacts with alcohol? Maybe there is an angel near you who can give you a camera module for testing. If the problem is not at the module it could save you buying a camera.
Did you solve the camera issue?
Some traveling later… My phone turned 5years!
The main camera is still broken but the selfie camera started working pretty quickly again after a restart. Week ago the screen went out after a fall and I cleaned some connectors with alcohol, also the back camera connector. Then the flash seems to do something when I push the main camera module in the right way (?!). Now everything works but the main camera.
So, I still have the same problem. :slight_smile:
It did change my life for the better tho. I saw myself so much in the camera that I changed my hairstyle and I deleted Instagram. + I now have people take pictures for me, I just point.
I will try to get in contact with a local Fairphone Angles Community to try to fix the camera.
Thanks @Jens1, @urs_lesse and @CFA
Hi @thomas,
If you’re still looking for a perfectly functioning FP3+ camera module, I have one last at the moment, selling it for 50€ + shipping if you’re OK with it.
Send me a PM of interested!
Hi Antoine,
Just wondering if you still have a Fairphone 3 main camera module available and if it’s a 48mp one?
Kind Regards,
Mike
Hey Mike,
Yes I do have one FP3 camera module at the moment. Its price is 40€ (+2€ or 5€ for the shipping, depending of the tracking option).
However it’s not a “48 Mpx” module, but you should know even the FP3+ only has a 12 Mpx camera module, 48 is the number or millions of photosites, but not pixels, it’s a misleading argument that Fairphone badly chose, in my opinion.
Honestly the difference between the two cameras is minimal.
However if you want to really improve the quality of the FP3(+) camera, you should check out the Gcam port of the Google Pixel.
Are you interested in buying my module?
Antoine
Hi Antoine,
Thanks for getting back to me so quickly.
I’ll check out that link you sent me.
The 12mp camera on my Fairphone 3 is still working (even though the stick-on window cover over it fell off a while ago and got chewed by the dog). I was looking to upgrade it but it sounds like there’s no need to if I can improve it’s performance with software.
I have been looking for a replacement battery for my Fairphone 1 (1st edition) though.
Is that something you can help with?
Kind Regards,
Mike
I don’t have any FP1 (neither FP4 nor FP5) spare piece, sorry…
No worries,
Thankyou for taking the time to respond.
Kind Regards,
Mike
Hello Antoine,
Did you sell that camera?
I have a FF 3 and the camera stopped working (not the selfie camera, that still works fine).
TIA!
Hi Iris,
Yes I did sell the camera module.
I sometimes have new ones coming, I post them in this topic:
For now I don’t have any camera left, but I regularly update it.
Thanks for the reply Antoine. Too bad you don’t have any, I’ll see what I do, not sure I can wait super long to replace it. I might even have to look into a new phone entirely.
If you know anything, do lay me know!
What have you tried to get the existing camera working again? Did you open the FP3, remove the camera module and put it back in already? I recommend to have a look at the posts at the beginning of this topic, too.
