How to set 4G for SIM card?
Due to severe problems after updating OS, I needed to go back to factory settings. Now I to get the one sim-card on which I have a 4G-subscription to provide me with the 4G connection. However, I get the screen as in attached screen shot 1, below.
Can anyone tell me how to get the 4G functioning again? (Settings at provider are ok, as far as I can see)
Could it be related to the fact that my sim-card does not have its phone number related to it? Screenshot 2 shows “number unknown”. How can I connect the card to the number I use?
Screenshot 1
Screenshot 2
Here is a neat collection of settings you should check:
Item 3 did the work: needed to set the other sim to 2g. Now it seems to work.
Thanks a lot!
