How to listen to music from SD card?
I have a new Fairphone and I have put a Micro Sd with music in it. But I cannot find the way to listen to that music.
a) hopefully you didn’t install it as internal storage.
b) try downloading a different music. if you are ok with downloading an apk and installing you may like to try.
https://apkpure.com/free-music-player-mp3-player/freemusic.download.musicplayer.mp3player
and/or
https://apkpure.com/simple-music-player-play-audio-files-easily/com.simplemobiletools.musicplayer
I recommend poweramp app, do a scan and it will find any music on your device.
Thank you.
I think I have understood my problem.
I had turn off the App ‘You Tube Music’ because I thought it was an App to listen to music in internet and I didn’t want that. I have turn on that App and now I can listen to my music in the microSd.
I am now fighting to introduce my emails in the phone without being able to do it.:laughing: I will continue trying it.
(By the way…I don’t undertand why they use Google software for this kind of smartphone)
With my best wishes for this year 1 P.C. (year 1 post-Covid)
Yes the default player is the youtube one, which I didn’t like and I had the same problem so installed alternatives :slight_smile:
Fairphone has to use some operating system and Google’s Android is the most common and available, and hence the easiest to modify to work on a new set of modules. There are people working on alternative Android options ~ you can search for Lineage and /e/
Thank you ver much for this information
