Hi !
EDIT : Just noticed my problem was similar as the one descrebed here : FP2 Battery Problems (drains quickly, CPU gets hot) - See batteryguide for workarounds
(I’m french, I hope I’ll not be too bad at describing what happens to my phone.)
I have a FP2 since 2 years now and I can’t use it anymore. I wonder if I must change the phone or if there is a way to fix it.
It began one month ago, the battery did last only 4 hours. The phone seemed to be more hot even when it was at rest. So I had to turn off my phone to be able to use it all the day, because otherwise i didn’t had enough battery. I thought it was a battery problem, so I bought a new one, but the problem still happens. I’ve noticed too that when i put the phone on charge the diode was no longer red (or orange?) but it was yellow…
I have try to delete some applications, and to turn off wifi, but doesn’t change anything.
Recently there has been new bugs. The phone has been displaying a white screen with “Loading” written. I had to turn it off by removing the battery to make it work again. Then when i put it on charge this morning the phone warmed up a lot. It was very hot to touch, especially the screen.
So is it a problem some of you know about? Do you think I can go to a repairer who can help me? Or my Fp2 is dead?
Thanks a lot!
Antoine
