As it seems Greenify can but not necessarily I kick-off this thread what shall us lead to an optimized Greenify configuration for the FP2.
DO NOT POST ANYHTING WHAT IS NOT RELATED TO GREENIFY
Wow, that is far, far longer than I have ! Could you post your greenify settings please ?
@cortomalese I reckon this question is adresses you.
Hello. I noticed now almost 24 hours of battery life, but I only charge it at 80%. It seems to me that it is related to the location where I am located, if I am on the go, the type and quality of connection available. But statistics show that the biggest consumption comes from display. I am also afraid that my battery is losing capacity.
My Greenify settings (active only):
mode root
Shallow hibernation active
Doze mode active. Doze on the go active
Automatic hibernation active
Greenify system apps active
All this is very complicated and time consuming
Good luck
Thank you @cortomalese !
I had almost the same settings.
I think the mobile cell quality has a really big influence… I have two sim cards and bad reception at work and at home, so probably a lot of extra power is used to boost the mobile signal reception.
