At the moment of launching the executable “FP3_flashall.exe”, after choosing “1” to delete all the data the program does not go ahead because “there is no devices attached”.
I try to go to recovery (Recovery mode is from LineageOS) and enable ADB (I had already unlocked it from the settings). The unlock (if I launch the command “adb devices” the phone is seen) and I re-issue the command.
The executable starts, sees the devices and restarts it in bootloader but stops here:
“press any key to continue …”
Well, then don’t continue, otherwise I wouldn’t be here … what can I do?
Hi and welcome to the community. Might be you need to install the fastboot driver.To do this: ensure your device is in fastboot mode and connect it to your PC. Go to Windows update. Manually search for updates (even if autmotically done an hour ago). go to additional updates and then driver and install whatever comes up with google/bootloader…
I noticed from the bootloader that there is no version for the bootloader on the device, could this be the reason? (sorry for the image quality but I have no other way)
Thanks everyone for the support but I finally solved it using another route!
Being a Driver problem I wanted to try Linux and it worked!
To be precise (maybe it is useful to another user) I did the procedure from EndevourOS (an Arck distribution). The package to install via paru (instead of apt-get apt and apt-get mtp-tools) is:
