FP6 Refresh rate dropping seemingly random
Same as title, i suspect the adaptive refresh rate dials down to 10hz (it feels very choppy that way) when it obviously shouldn’t, cannot reproduce the issue in a reliable manner, android, build fp6 qrel 15 91 0
Additional question, the long life cable seems to charge the phone for 5 seconds, then stops and begins charging again immediately, making the charging sound over and over again every 5 seconds, does not happen with another cable
I noticed one refresh rate drop as well today, seems like a bug. But I did not have chance to charge the phone yet (even after playing with phone and installing lots of apps since yesterday it still has 42% left from initial 70% :exploding_head:).
So far it seems like I will be charging tomorrow in the evening. But I tried with old Baseus cable (slow charging enabled, cap at 80%) and it held for ~1min without any issues.
Does the issue appear with fast charging enabled? Could it be charging brick related?
I only noticed it after unlocking the phone, but i certainly have it aswell, just not always. What might be different, when it occurs is, that i switched wlan (either completly outside of my wlan or switched to another repeater) but it might not be related at all.
@all please report to FP support.
I have just migrated from Fairphone 4 to Fairphone 6.
It’s a great phone BUT I have an issue with the screen.
Very regulary, after unlocking my phone, refresh rate drops from 120hz to 10/20hz during 30s.
Screen becomes very slow, with lags and jumps.
To fix that, I must to lock my phone or wait…
It’s very regulary and random.
Do you know a solution ?
Thanks in advance
Same Problem Here with the Refresh rate. I Just do a Restart then its OK again. Cant relly reproduce when this Happens but usually right after unlocking the Phone.
What animation factors are selected in the developer settings?
I’m getting this too. Plus I got a Google photos upgrade and now when I take a picture it hanging with “Processing”, then loses the photo. Disabled sync to Google to stop this.
Same,plus the Video ist super slow,watching gallery or YouTube .10hz
In case anyone missed it, the status quo from Fairphone:
For information, I selected 0,5 for all types.
I hope it will be help.
Statement from Fairphone
I did a Smartphone-Reset because of an other issue and now the problem with the frame drops disappeared. Everything runs smooth.
No idea if this will help everyone but it did it for me.
Same Here. FPS randomly drops. As If some Backgroundprocesses occure and slow the Phone and menu Handling down
Still after the update of today?
Edit: yes, it’s still there
This is still happing as of July 16 unlock phone and its oke and normal or its 10hz refresh rate at random only work around is to just relock the phone and unlock it again… What a freaking pain i have also used the phone wen this was happing and it takes a long time before it goes away… So not worth w8ting best to just re+unlock the phone
I wanne say this happened before i move all my stuff from my oneplus 5 to the fairphone 6 but it was allready doing this out of the box wen i was just using the phone to test it (use chrome check settings try youtube etc) i dit not have anything installed yet or logged in yet…
I really like the phone but my god i cant recommend this phone to anyone with this kinda :beetle:how do you even release a phone and over look this
Are the devs even using the fairphone 6 them self?
I suggest you to try to enable only the pin or the sequence to unlock the phone, with this configuration the problem seems to happen a lot less. Before I had both the face recognition and the fingerprint and it was very frequent
oke gone add 1 more onto it you think its just 10hz but its even more random that every time i unlock the phone its smooth 60hz or 40 or 30 or 20 or 10 setting the phone back to 120 and its less of a problem but i bet its still dropping it something els thats not 120hz and today i tested it again but the screen set at 90hz and its happing more and more again so mid day i set it back to 60hz
and my god now its happing almost every single time i unlock the phone
so i set it back to 120hz and it was less of a problem
so for what ever reason the OS set the refresh rate to a random number wen ever you unlock the phone and if you set the screen refresh rate lower its get way way worse… my god this needs to be the next thing they fix in the next update this is pure ***sht
it was happing even before i set a code to unlock the phone
There’s clearly an effect on battery life if they get this wrong, so they clearly didn’t rush it into Monday’s update.
