:GB: đŸ‡«đŸ‡· FP5 reinstall FPOS
Bonjour, pour ma part, je regrette d’avoir choisit cet OS de Murena parce que les compatibilitĂ©s ne suivent pas. Je viens d’acheter une samsung watch8 qui ne peut pas ĂȘtre configutrĂ© sans le galaxy wearable et celui ci ne fonctionne pas car il dit que le service google est pas Ă  jour. J’ai pourtant mis la version BĂ©ta de e/OS du 28 juin. Et quand j’essaye de lancer fastboot pour repasser en full google, impossible de faire reconnaitre le driver de mon FP5
:frowning: NB : de la part de Samsung , je trouve ça lamentable, tu peux meme pas dĂ©marrer la conf de la montre sans passer par un telephone !
Kindly stay in english in this topic and confirm you are using a FP5 or FP6?
Hi, for my part, I regret choosing this Murena OS because the compatibilities just don’t keep up. I just bought a Samsung Watch 8 that can’t be set up without the Galaxy Wearable, and that doesn’t work because it says the Google service isn’t up to date. Yet I installed the Beta version of e/OS from June 28. And when I try to launch fastboot to go back to full Google, it’s impossible to get my FairPhone5 driver recognized
 :frowning: PS: From Samsung’s side, I think that’s pathetic, you can’t even start setting up the watch without going through a phone!
Thanks for clarifying. I opened a topic for you in the FP5 category and indicated french and english as topic language
please specify what that means and which system you use on your PC.
With a UpToDate W11, i have tried all adb and google drivers but I still have a yellow flag on the android line.
Also
Ok thanks, finally, fastboot unlock is down. Now FP5 is on fastboot mode. But when i clik on the official package "flash_fp5_factory, nothing append :frowning: (i have disable smart app contol on W11 and i am logged with admin user)
ok, this step is passed.: just launched by powershell with “.\flash_fp5_factory.bat”
