Iâm living in France and working in Monaco. When in this country, I experience randomly a short full-freeze (maybe 3 seconds) followed by a reboot. It happens several times a day, sometimes 4 times during my lunch break. It never happens in France (or really rarely).
My operator is Bouygues from France (which has antennas on the other side of the border I think). I usually get the 3G, and sometimes a quite unstable 4G (quite common for foreigners).
My build number is FP4.SP29.B.069.20230510 . I bought my phone in December 2022. I think that I did not have the issue at the beginning and it started with an update, but not sure at all.
I tried several things without success:
enabling only 2G/3G (I donât have 5G subscription)
disabling roaming
forcing Bouygues 3G network
disabling 4G calls and MMS
Iâm also using a bluetooth Shokz headset. I donât have stats with bluetooth disabled.
I used once Wi-Fi and no 3G/4G a day and had no crash I think, but I need to retry to be sure. (it would not be a solution, I only have wi-fi at work)
I donât have any logs of the system yet to track what happens before the last reboot.
Iâm out of ideas and itâs very annoying (even if the reboot is quite fast). Any additional idea is welcome.
07-04 14:11:47.789 3544 3544 F libc : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 3544 (init), pid 3544 (init)
07-04 14:11:47.812 3544 3544 F libc : crash_dump helper failed to exec, or was killed
Hi, I did not try to contact my provider (I donât expect any help).
My SIM card is 2 years old. Random reboots is unheard from colleagues with the same provider with a phone from a different brand (I did not have any particular issue with my previous phone (a Galaxy A5 2017) with the same SIM card.
I forgot to say I donât have any SD card.
The provider has to do their part of homework to support a device properly. Also, even if a SIM works in another phone it not mean its not faulty. So I would contact the provider and Fairphone support.
Quite likely. Taken with (?) no problems when not using mobile data, for me this points to an adjustment required either on the carrier side or FP side, possibly both, but they need to talk, so Iâd advise contacting both. Check which carrier youâre using on the Monaco side, but equipment and configurations may vary even with a single operator.
Today I disabled the 3G/4G and used only the Wi-Fi and did not have any reboot.
I did not try yet the Safe Mode (as suggested as a preliminary step of support), so Iâll do that next week and contact the Fairphone support if the problem is still there (I bet it will).
Thanks to all of you for your suggestions.
The same thing happened to me both abroad ( Cech Republic) & in the UK⊠what makes this so serious is that it is location dependent⊠to travel on a trailway journey - it will start rebooting in one area and then be OK in another, bad luck if you get off in an area that is affected - there is no fix other than disable the phone. I replaced the SIM and did a hard reset to try to fix itâŠ
After this, and the brightness bug where it is unusable outdoors , I sadly relegated the FP4 to being a spare :-/
Thatâs strange, because AFAIK there are people in the UK having the FP4, if there was a specific issue with the local network(s) they would had already spotted it.
You said âabroadâ, this means your phone is roaming: Have you checked which operator it uses when this happens? Is there a specific one, or does it happen with several different?
The strange thing is you said that you tried disabling roaming and still had crashes, despite still using the french Bouygues network. What is the difference between using Bouygues in Monaco, and using Bouygues a couple kilometers away in France?
Youâve mentioned âunstable 4Gâ, but that doesnât necessarily explain anything either. Iâm sure there are lots of FP4 users with unstable Bouygues 4G connections in France, they would had noticed if this would consistently cause crashes.
So, what is the special, Monaco-specific thing which causes your FP4 to crash?
You say working in Monaco, so you clearly spend a lot of time there. Are you sure your phone only crashes while in Monaco? Does it perhaps crash just as often in France, but you donât notice it (because you donât need it so much while at home for instance)?
FP4s do experience the occasional unexplained random crash, yours might be starting to get specially âtouchyâ.
I donât know how is organized the network in Monaco. I donât know if Bouygues have towers within the country, or if from the neighborhood of my office I get cells located in France. Given that I never had any roaming message and that my phone always displays « Bouygues », it would say I only get Bouygues network.
Note that in some parts of the âcountryâ (itâs more like a town), many people with French providers stop getting any network. Itâs my case with Bouygues (and I think itâs the same with Free).
Sorry for not being precised enough, I did not want my message to become too long. I meant than in Monaco, my phone (and my previous Samsung phone) switches between Bouygues 3G and Bouygues 4G. The 3G is more stable, but with 4G I sometimes lose the data connectivity for a moment (a least 1 minute) and then either the data is back or it switches to 3G. I donât witness such problem in France.
Iâm 100% sure it happens only in Monaco, or much much more frequently in Monaco. My use is of my phone is:
2 days a week in Monaco, on 3G/4G => several crashes a day (I would say roughly 6; more frequent when I use data like listening podcasts or browsing, but I can happen randomly, maybe when apps communicate in the background). Note that the network does not send my any message that Iâm roaming.
at home, Iâm always in Wi-Fi. So I expect no crash. I would notice: I need to enter the PIN code for a complete reboot.
outside, in France (when doing sports, groceries, commutingâŠ) I get no crash.
Yes, such a number of reboots is annoying as one can guess. Not to the point that I would switch to my previous phone back, but annoying is several scenarios.
Me neither. I havenât been there for at least 10 years now. You say there is no roaming message, so it seems there is some agreement through which French operators cover it just like the French territory.
Thatâs normal, it chooses the best option, and if itâs not working falls back to the inferior one. That shouldnât make your phone crash, itâs something happening all the time (except in a big city). I live (mostly) in the boonies and have my fair share of âphone looking for a reliable connectionâ (FP4 too, Orange FR).
Meaning that this shouldnât (normally) be the cause of the crashes.
As much as it pains me, I think your only hope is to check with BouyguesâŠ
It seems they do something special with their network relays inside Monaco, something the FP4 apparently doesnât likeâŠ
That would mean it depends on specific conditions being met.
Iâd suggest both you and @Veloman contact support (with as precise information as possible, including use of 5G or not), because this might indeed be fixed in some future network driver update.
If it doesnât only happen in Monaco and/or Bouygues, it must be due to the FP4 not playing nice with some specific-but-not-uncommon network setting.
Je disait juste , de te connecter en wifi au lieu de la 5g et de voir si tu as les mĂȘmes reboot, histoire de bien ĂȘtre sĂ»r que câest la carte sim qui est en faute .
