FP4 - gcam-port
Yes, makes no difference.
Did it (pm uninstall -k --user 0). GCam wants to have photos installed from play store. GCam Photo Preview cannot be installed (“…not installed”). Perhaps GCam Photo Preview is meant to be used only with CalyxOS?
as described in the linked thread what you did is not sufficient…and no it works fine without Calyx
I think it is not installed if gcam says I have to install it from play store. What else is necessary?
If I get it installed, is it just another gallery app or does it add the choice to use any gallery app?
it adds the choice to use the preview and open the gallery, so instead of getting this message telling you, you need Google Fotos, it will open the Gallery. My understanding is the package name is the same and with the commend used its not uninstalled for all user/completely. The command uninstalls for user 0, so its still there. How to remove completeley with root is a question for Hirnsushi :wink:
You are right, it seems to be not sufficient.
I reinstalled photos from play store and removed it with
pm uninstall com.google.android.apps.photos
After that gcam asks for the gallery app (f-stop in my case). With other words: It works now, even without GCam photos preview.
Thanks for the helpful tips.
What is that your using there?
Here you can get the newest version (actually 0.4):
https://gitlab.com/CalyxOS/calyx-fdroid-repo-apks/-/raw/main/GCamPhotosPreview/GCamPhotosPreview-common.apk
The version in your link is the initial version without the menu, to can edit, delete, etc… directly in preview
i think you mean iodéOS
It is a custom ROM for FP4
I got my Fairphone 4 yesterday. Can I install another camera apk to test the difference with the standard camera app from Fairphone? Which apk do you advise? Can you provide a link? Thank you so much.
Hi and welcome, you can and links to the GCam ports are already included above im one or the other post, just test which you like best, for me its Nikita over BSG, example pictures here
Hi All,
I hope someone has found a solution to this.
I came from a Google Pixel phone to a Fairphone. I just love the Google Camera App. Then I found someone had a method to bring it over to the Fairphone. Happy days!
Except…about half the time, when I open the Google camera app, the camera doesn’t work. No image is seen, no image is captured if you click on the button.
The only “solution” that I’ve found these days is to restart the phone (and wait a minute or two). Other things I’ve tried:
  • turning phone on/off
  • switching to another app, then back to the Google Camera app
  • killing the Google Camera app, and restarting it
  • killing the Google Camera app, and starting the Fairphone Camera app.
I haven’t tried getting the console messages to see if there’s any logging that’s going on.
Anyone found a good solution (or a camera app that beats Googles (when it works)?
Which one exactly of the many GCam Ports do you use?
edit: moved your post, please also see above.
Edit2: else do some reading in the forum reg alternatives etc.
https://forum.fairphone.com/search?context=topic&context_id=94955&q=FP4%20camera&skip_context=true
This file is no longer available. I am very interested to get a config file. Is there an updated version somewhere?
No, sorry. Don’t use a FP any longer
Which phone did you switch to, out off curiosity?
I’m using the snap version from this port without any issues:
Keep in mind to set “Surface List” of the 0,6 camera module to “from HW FULL”.
Where I ll find this “surface list”? I can t find it in settings.
I installed MGC_8.7.250_A11_V11 by BSG on my FP4 and Im not sure which interface is preferred for FP4. From default I had set Pixel 3 and photo looks like made with fish-eye effect. What should I change?
You need to switch from the wide angular lense to the normal one
BTW, the latest stable version is MGC_8.7.250_A11_V15a
see BSG: MGC_8.7.250_A11_V15a
