At least the version I have (8.6.263) has that option.
I’ve been using the BSG GCam for a while now and I’m quite happy with it.
Can’t say much about the features compared to the others, my main reason for choosing it was that it’s usually the most up-to-date one.
I want bleeding edge, if stuff doesn’t break once in a while I get bored
Thats weird I have this setting as well with FPOS A11 and the Nikita GCam port 8.2 v1.8…does BSG provide different versions as well (like snapcam or samsung…) and might this be the reason?
Both have different package names. The older one ( installed as org.codeaurora.snapcam) has the option, the latest one (installed as com.android.mgc) actually doesn’t.
I’ve installed them with their package names switched and that didn’t change the outcome, so the functionality definitely depends on the version.
@jochen0 could you try the 8.6.263 version I linked above please
The different package names are solely there to make it easier to have two different packages/versions at the same time.
I use MGC_8.7.250_A11_V6 for testing and as stable version MGC_8.6.263_A11_V14 from BSG
They exist because of allow lists in some Android ROMs. If you install the version with the right package name on those, GCam gets additional access to something like the AUX lenses for example.
