Pixel 6a with iodéOS
Half of the price for double of quality, I think that’s also a Fair Phone ![]()
I often say the Fair bit of the phone refers to the and success in ensuring better working conditions and wages for miners and factory workers, not the end user of a mobile phone.
Thanks, working on it.
those of you who use the BSG mod, are you able to use the flash? on my FP4 with CalyxOS the flash toggle just shows “unavailable” with flash controls turned off. the flash however works fine in Calyx’ default camera app.
Yes, I am using the latest 8.8 built on FPOS A12 and the flash is working fine.
On 8.7 it works aswell. But I miss the option to to have a torch flash. It is just flashing when taking the picture. Is that available in 8.8?
Btw. I am using Calyx, too.
I downloaded GCam from here (BSG), and the change is amazing. With the “Pixel 6 - Oriole” mode we have flash and night-mode, 4 types of video stabilization, the colours and the images in gloom and darkness are great, the 2 API cameras (OISS and Ultra-Wide) works perfectly, the resolution of images is better (a lot)… Really this is my main camera app, cause I think this software shows the impressive quality of the hardware.
Which version did you use? I tried the snapcam version (thats the version I am using with the Wichaya gcam) but it wouldn’t install… Just ignoring my tapping on the apk-file…
This: MGC_8.7.250_A11_V11_MGC.apk. I have a Murena Fairphone 4. And I gave permission to install apks out of App Lounge. But everything went without any problem.
Have you had any problems with this APK camera app going black at all, and did you just use it out the box or tweak some settings to start with? I am having the same issue as @Ken_Corey highlighted earlier in the thread!
Yes, 2 times. But the reason was clear: I passed from “photo” to “video” with the 0.6 camera (ultra-angular), the app doesn’t support it, and went black and shut down. This app, and every other camera app. I restarted the phone, and everything good.
Which specs do you use in the app? There are so many options. Thanks.
I use…
- Interface Pixel 6
- Frequent Faces
- Automatic Exposition
- Auto Night Sight
- Max resolution
- Video stabilization
- Audio zoom
- Selfie as in preview
- Google AWB
- HDR+ Enhanced
- Aspect 4:3 (Full picture)
- Video resolution Full HD (I think 4k is too big, and Full HD is really good resolution for me) / 60 frames per second.
- Front camera works really very well too, in Picture and Video.
In Video, “Slow motion” and “fast motion sequence” works perfect. And the 4 kinds of “video stabilization”.
In Photo, Ultra wide angular / 1.0, Night vision and Portrait works, and are great. And Flash works very well too.
Great. Thanks a lot for the prompt reply. The gcam makes a big difference. I’m starting to enjoy taking pics with my FF4.
Anyhow, I have two questions left.
Does the interface (e g. Pixel 3 or Pixel 7) make a difference in picture quality?
Where can I find the option to enable frequent faces?
Thanks so much!
I think the interface doesn’t make a difference in picture quality, but there are some particular features that depends on the interface.
I think “Frequent faces” and the 4 different types of Video stabilization are not in “Pixel 3”. And there are some features of “Pixel 7” (Cinema mode, for example) that don’t work on my FP4 (the app crash in “Cinema mode”).
For me, the interface “Pixel 6” is the best.
But all of this is only how the app works on my phone, I don’t know if on another phone things are different…
Hello everyone.
I was using GCam_8.1.101_Wichaya_V1.4_Snapcam and I was super happy because the only thing that was bothering me with my FP4 (FPOS) was fixed. Recently I got the cam driver freeze’s problem mentioned here.
To fix it, I tried several Gcam ports recommended here and non-recommended Gcam ports. I ended up with SGCAM_8.5.300.XX.10_STABLE_V4. All features work for me and the cam freezes are gone so far.
I hope this is useful to some of you.
I’ve been using BSG’s GCam for a while now, and all versions up until 8.9 have been working fine. whenever I try one based on 9.1 though, it always crashes when I try launching it by double pressing the power button on homescreen (weirdly enough, it doesn’t crash when I do that from the lockscreen). has anyone had that happen and perhaps found a solution? I’ve had that happen on CalyxOS based both on Android 13 and 14.
No solution but same behavior here for the bsg 9.1 under iodéOS on the FP5. ![]()
I still use it, as I mostly open my camera from the lockscreen. Within the OS via launcher works.
I’ve just realzed that the camera generates logs on crash in a dedicated folder in the /Downloads/MGC_CRASH_LOG/ directory. I guess they could be of use for the person behind the mod, but they only seem to provide support on Telegram, and I can’t seem to be able to regain access to my long-forgotten account ![]()
Update on the crashes: The most recent BSG MGC 9.1 version is now working on my phone. The 9.2 version crashes.
