FP3 getting slower
My FP3 has gotten slower the last couple of months, and some apps crash from time to time (Teams, Outlook, Simplenote etc). Maybe it’s because of an upgrade, I don’t keep track of those things. Still - I thought a Fairphone would last longer than the four years I’ve used it. That’s not much better than the iphones I’ve had.
Also, if you are using an SD card configured as Internal Storage … sdcardguide.
Thanks for the suggestions. I have a lot of storage left, and don’t use an SD card, so then only the factory reset is left. I’ll try that when my patience has worn out… :slight_smile:
