FP3 - 2 sim cards: Calls preference
I am using 2 sim cards and would like to be asked before any call, which sim card to use. I set:
Network and Internet/sim 1/Calls preference: ask every time
When I not restart my phone, this option is always resetted to :
Network and Internet/sim 1/Calls preference: sim1
Is there anything I can to to fix this?
P.S.
The same with
Network and Internet/sim 2/Calls preference: ask every time
Network and Internet/sim 2/Calls preference: sim1
When you restart the phone, is the phone then asking for a pin code for both SIM cards?
When restarting the phone, it is asking for the pin of sim1.
Hi
Have you set a PIN for SIM2 ? If not try setting one.
I set a pin now for both sim cards, but the problem persists. I’ve restarted the phone several times and set the preferred calls settings to ā€œask every timeā€. But after every restart, it sets the settings back to:
I have a similar issue. I have set sim1 as preferred for text, data and calls, however, after reboots it always switches to sim 2 for calls. Ultra-annoying.
There are other resets noted.
See if you have the Digital Wellbeing app enabled and if so disable. Here are a few examples.
