FP2: Android 10: Fairphone OS / Fairphone Open 23.02.0-rel.0
Fairphone OS & Fairphone Open 23.02.0-rel.0 are now available. You can get them through the Updater. This is the final release for Fairphone 2, as software support is ending.
Changelog
Issues fixed since the previous Android 10 release (22.12.0-rel.0).
  • 2023-02-05 security patch level
    • from the Android Security Bulletin—January 2023:
      CVE-2022-20456, CVE-2022-20461, CVE-2022-20489, CVE-2022-20490, CVE-2022-20492, CVE-2022-20493, CVE-2022-20494, CVE-2023-20905, CVE-2023-20913, CVE-2023-20915, CVE-2023-20920, CVE-2023-20921
    • from the Android Security Bulletin—February 2023:
      CVE-2022-0850, CVE-2022-20006, CVE-2022-20441, CVE-2022-20451, CVE-2022-20455, CVE-2022-20481, CVE-2022-39842, CVE-2022-43680, CVE-2023-20932, CVE-2023-20933, CVE-2023-20943, CVE-2023-20944, CVE-2023-20945
Changes specific to Fairphone Open:
  • Update Chromium WebView to version 110.0.5481.87
Please report any (new) issues through the public bugtracker and upvote existing issues if you are affected. As usual, please specify the steps to reproduce, and provide as many details as possible.
What a bittersweet moment. :worried:
Thank you for your SUPPORT :slight_smile: :+1:
That’s not really necessary anymore, I’d say. Rather “Please live with any (new) issues” from now on…
Anyway, thanks for supporting this device for such a long time! The update went smooth again, no (new) issues so far.
Thanks for 7 years of support!
Update went smoothly.
  • Is there a roadmap or a plan for how long the FPs after no. 2 will be officially supported?
  • Is there an overview of mobile OSes there are?
    Maybe also which run on the FP2?
    Additionally, maybe which don’t inherit (?) from Android?
For a list see here #oslist
Else plans are described here
#oslist has no topic atm…
Click on the topic
thats not correct…
When I search for it, I get a No..
why do you search when you have the link :wink:
and did you search the tag really?
The second did only pop up after rechoosing the search string…
And yes, I typed ”#oslist“ first, then I ”Strg+Click“ed on the link in your post (15:30).
It’s a pity that you do not support FP OS anymore. From my point of view, this is not a sustainable decision. I have the phone since 5 years and want to go longer. But no support means, that I have to think about an other solution.
Does that include installing an alternate OS ?
Well, yes of course. I am thinking about Lineage OS but I have to first to learn how to do it.
:slight_smile: Hopefully you have checked out
https://forum.fairphone.com/search?q=Lineage%20for%20FP2
If you feel you need help or advice
