Hello
First of all, sorry for bad english.
Second, contratulations and thank you very much to all people, developers, testers and so who make fairphone posible.
Now… I just wanted to share the fix I found to the typical problem: “fastboot mode not being detected in windows… (10 in my case)”. Because I turned crazy looking for solutions and trying …., I spent several hours, even several days…. Till I thought and tried something different. As I was installing drivers and more drivers and none worked, I installed more and more…. and then, I thought my system was swamped and needed some clean. So I tried this: I went to device manager, and uninstalled the android, choosing to delete its associated driver files. Then, refreshed devices and repeated again and again…. untill the Android device detected had no driver associated. Then I manually installed it by chossing “let me manually installl …” and then I unchecked “show compatible”. From the list, I choosed Android fastboot device (or something alike, I do’t remember exactly) and YEP, it worked !!! Just that way, no need to install more drivers.
Hope this helps someone with this problem. Windows update and automatic didn’t work for me and I had to do this way. Hope it helps someone or even myself in the future.
Have a nice day and a nice e os using !
