Thank you for the info! I was actually reading this topic right now…
I only wish a “Fairphone 2 manual user” would exist (or does it and I did not find it?) as it did for Fairphone 1.
I used to have a very old and simple to use smart phone I have to admit it is difficult for me to fully understand how this OS works…
Just opened the link… That is the paper they sent with the phone! Which I already read!
I hoped they would have gave more info. For example about the “Amaze” app (How to improve the use of this app?, how to create short cuts of the different files?, etc…), or why is there only google app pre-installed (except Amaze) and not at least the normal none app “gallery”… Anyway, I guess it will just take me more time that I thought to set my phone the way I like (which is probably a bit old fashion). But I should manage.
The file is in /res/images/charger/battery_scale.png, but you’ll have to work on it a bit (it has to represent different charging %ages so it’s veeeeeery stretched) :
Had to reupload to imgur because the forum software sucks
It’s not really a first impression as I already have it for almost 2 weeks but an impression by using it:
It’s too big! I can’t handle it with one hand… depending what I have to do… It hardly fits in my palm. So now I have 2 frozen fingers (EDIT: I meant hands) in winter…
Edit by @Stefan: Title was “Is there any Fairphone 2 working fine?”
Ok, the title of the topic is a bit aggressive, but no offense, I’m seriously wondering. I’ve read countless posts about common bugs, like baterry problems, Spotify crashes or Maps not working well, or the touchscreen acting crazy. Mi FP2 will arrive this week or the next one, and now I’m a bit scared if my phone will not work…
Could you please guys give me your impressions about the phone, how it works for you at the moment, pros and cons and if you are happy with it? I’d appreciate it, thanks a lot!
Well, I’m happy, even though some things are “glitchy”:
- notification led. I had none before, but a nice feature shortly activating the display, so, ok, but the fix would be nice.
- Exclamation mark on WLAN notifyer, when switched between my 2.4 and 5GHz WLAN. WLAN works, but people report more battery usage. I’m not sure whether I see this also, maybe the battery lives somewhat shorter. Well, the battery might be relatively small, but then my SOT is up to 3h, so ok…
- I’m not sure whether this was a problem, or caused by external reasons: I had problem with mobile data, every now and then I had no data, and a message like “Mobile Daten gesperrt”, mobile data disconnected and locked this way. But this was shortly.
All in all, for me this are minor things, but I’m longing for an OS update
I have got the same worries. Mine is also going to arrive in the next weeks.
I have read about so many bugs (screen flickering, random reboots, bluetooth issues) that I really wonder how I will be able to use the phone on a daily basis without getting frustrated by it.
I really hope that there is an software update coming soon that will be able to fix all these bugs. But from my understanding of the other threads and the official bug list is that the cause of the more concerning bugs (the bugs I listed above) is not yet known…
I have my Fairphone 2 since Friday. It is my first smartphone.
My impressions until now:
- It’s more beautiful than on the photos.
- The performance of the Fairphone 2 is very good. It runs smoothly, no sudden hangs, crashes. It makes fun to use the FP2.
- The battery is draining quickly when the phone is in use. When the FP2 is in the anorak pocket at work without Wi-Fi and is not used, it is very energy-saving (only ca. 0.75 % per hour!).
- I did not manage to take the screen off. Also, taking the back cover on and off is very hard.
- The phone is reacting quite slow to the sensor inputs (screen rotation, turn screen on when taking from the ear, brightness change).
- Also, the GPS position is “jumping” (not moving smoothly) when driving. (No fear, I was not the driver!) But the GPS fix is very fast.
- I have no bugs which are told on the forum and make the phone unusable (e. g. frequently random crashes and reboots, not charging, misbehaving apps). Only the jumping Wi-Fi symbol (which also affects the mobile network symbols) with exclamation mark and seldom the flickering screen. Only two random reboots since I received my Fairphone 2.
- The Dual SIM handling has some annoying behaviours:
- You can only set SIM2 to 4G when you set SIM1 to 2G only before. (It should be possible to set SIM2 to 3G/4G even when SIM1 is in 3G/4G mode. Then there should appear a warning and SIM1 should be automatically set to 2G only mode.)
- In the pull-down menu, only SIM2 (which is set for data usage) is shown.
- I have set SIM1 as the outgoing call/SMS SIM. You have not a setting to bind a contact to SIM2.
- I have googled and found a way to turn off the Google enforcement of the contacts app.
- The notifications from the Twitter and the e-mail application are appearing quite fast. I turned off my Google Apps Script application which would send me SMS of some tweets. Also, I can now send and receive signed and encrypted e-mails with both S/MIME and OpenPGP even with my FP2 and can handle the e-mails better than with the two pre-installed e-mail applications (which I disabled). (Well, my contact partners aren’t using e-mail signing/encryption. I only configured e-mail signing/encryption as a matter of principle.)
Disclaimer : I’ll update this post with my impressions as the time goes (hence lying a bit with the title of this topic, since these won’t be my first impressions …).
It seems that I’ve had the bugs everyone had (flickering screen, the phantom touch inputs, the HIGHLY CRITICAL wifi symbol glitch, the rebel apps, bluetooth sound issue and the notification light problem).
For me the bluetooth issue is quite painful, since my mesh has the issue. I don’t have it on my car, however, the sound is crystal clear.
Context: my previous phone is a Sony Xperia V. It has a 4.3" display, 1GB RAM (700-ish usable), LTE, a 13MP camera, NFC, and an sd-card slot. I’m using it running CyanogenMod 11 (based on Android 4.4.4). Because of some apps I’m using, the phone is rooted.
Delivery: the phone was delivered to my place on the 4th of January, for an estimated delivery date in December. Not bad, given the end of year holidays. I was a little bit disappointed to receive it on the end of my holidays, but overly happy to finally have it !
Packaging: A nice recyclable minimalist package, which contains what’s needed : the phone, the back cover and a quick start guide (@anon90052001 : thanks for not having cut down a forest for the usual paper brick we can find in the phone boxes, along with the ton of plastic bags that usually present as well).
First contact: the phone is beautiful. It’s quite big in my hand, but I guess I’ll get used to it. The battery charging animation is ABSOLUTELY STUNNING. The phone is quite long to boot though, I think it’s a bit longer than my previous phone (quickboot is disabled, as I like my phone switched off, when I switch it off
). The black background with the components got my vote, it’s fabulous. I also like the default ringtone.
Playing with the back case: it’s quite difficult to wrap around every corner. I think this is a very positive thing, as the FP2 is solidly tucked into its case. Plus, after a few tries, it begins to be easier and easier.
The system: in spite of the several bugs aforementioned (which I don’t doubt will be fixed, as many users seemed to have experienced them), the system is smooth ! The animations are very fluid, all components are responsive. I’m not quite used to the Fairphone launcher 3, so I have installed (for now the catapult launcher).
Storage: I had a hard time with my sdcard: the exFAT filesystem was not recognized. @keesj : do you know if the driver is present in the FP2 kernel / as a module ? To solve my issue, I have emptied it and formatted it with the storage app. The microsd slot is quite tricky to operate : I have to put a knife under the card and pull it gently, else it doesn’t pull out (this is not really a defect : I don’t change my sdcard once a week). A great feature : it’s possible to directly mount the sdcard (i.e. without using MTP) via USB ! That’s great !
My wishes:
- Some instruction to root the phone (I know this is a polemic topic, so I won’t detail what’s already on another topic).
- The possibility to customize the notification color depending on the notifying app (for example, blue if I have an SMS, red if I have a mail, and purple if I have missed calls)
Some drawbacks:
- It’s quite hard to listen to music while charging the phone, as the USB port is on the “bottom” of the phone
Some things I don’t understand yet:
- Although the “swipe” keyboard is enabled in the settings, swiping input is inoperant.
- I can’t find the “clear recent apps” button in the recent apps drawer
- The audio playback resumes after hanging up a call, and I couldn’t find an option to disable this
- The default lockscreen does not display the audio playback controls (<<, pause, and >>)
EDIT 2016-01-13 : the last 3 items of the “I don’t understand” + changed the “fastboot” term to “quickboot”. My apologies, @Stefan and @MaartenD.
Where? I don’t seem to find it…
Settings > Sound & Notifications
It wasn’t disabled… So that’s not it…
Gesture typing doesn’t seem to work with the AOSP keyboard, you will need to use the Google keyboard or something else.
I was tempted to make a photo of the Post NL fan with the delivery man walking to my door, but I hesitated for I think it would be an invasion to his privacy, so I made a photo of the unpacking instead:
.First impressions:
size Not as big as I thought it would be, it does fit in my pocket after all, no need for a belt sleeve.
SIM The SIM slid in easily (though I had to get rid of the glue on my card that got there by having me put the card into an adapter for the few days that I had it cut down to micro-SIM size but still needed it in my old phone before the FP2 arrived).
micro SD-card The Micro-SD didn’t slide in easily nor does it get taken out easily due to two tiny protuberances that keep it place. Also, it makes the rubber band round the screen bulge a little where the SD-card sits (it’s a vulnerable spot for the rubber band, as there’s a slot for the on-off button in almost the same place. I did take the SD-card out, as I don’t really need the storage space, I just thought it would be an easy way to get my old music back).
protection It was quite hard to get the back cover round the phone, especially to get the rubber band to slide round the screen, I used a letter opener made out of a non-sharp material but with a tiny point to get the rubber slide round the screen, just as I use a tool to get a rubber tyre fit onto the wheel of my bike. But as I wrote above, the place where the SD-card and on/off button sit, shows a slight bulge in the band, where it’s a bit loose and doesn’t fit well round the screen. The screen itself is protected by a foil, that gets held in place by the rubber band that goes over the screen for half a millimeter on all the edges, but the foil is maybe more meant for transport than for permanent protection? I left it on though, even though it’s a bit loose - handling the phone while trying to fit the back cover easily makes air bubbles beneath the foil that needs to be pushed out again.
USB connection My old cables, stemming from mp3-players and tablets had mini-USB connectors, I found out the micro B-USB that’s needed for the FP2 is different (even tinier) so I had to get into town first to buy a new cable. USB speed was fast when loading data (music, documents and movies) from my computer onto the FP2.
screen I immediately downloaded my favourite viewer apps from the Google Play store (I did use my old Google account created for my tablets, so I could make use of the apps I paid for for my tablets): FoxIt for pdf’s and Moon Reader for epub’s. The screen is large and crisp enough to read books upon without straining the eyes, which was a surprise to me. One of the benefits of having a smartphone, is having books with you at all times for lost moments.
One thing I do miss on the screen, is the ability to put more than 4 app shortcuts next to each other on the homescreen, nor is there a bottom bar that stays on all screens. I could use the Nova launcher instead that I installed to make my Samsung Tab faster and that allows for many more apps to be placed on a screen, but that would mean losing the quickstart screen for most-used apps that’s opened by swiping from right to left, that Fairphone advertised and could be handy, once I make a habit of using it.
music quality A much bolder sound than I’m used from my Sansa Clip +, it has power, but is also a bit rough, can sometimes rumble a bit in the mid-low range. My gripe with my Sansa Clip was, the quality was good, but I had to position my Sennheiser CX300 earplugs very specifically balanced in my ear to get a full sound or I would just hear the higher frequences. The Fairphone has so much power, it doesn’t seem to matter much how well my ear-plugs are placed. It does lack a bit on definition though. But my experience with audio devices, be it amplifiers, earphones or mp3-players, is the more high-end a device is, the more time it takes for the sound to ripen. Any amplifier, headphone or mp3-player I owned that was worth it’s money, sounded a bit dull and lacked the higher end frequencies in the beginning. I expect the Fairphone to behave the same. Best thing to do is play pink noise for a long time on high volume, but lacking a pink noise generator, playing lots of different genres in alternation for a long time works as well and that’s what I’m planning to do.
stability My FP2 has been fast and stable on this first day and there was only one bug I encountered: the exclamation mark appearing next to the Wifi icon after getting back in Wifi range when returning home. I’ve read on the forum that when it’s giving that warning, it uses a lot more battery power than without. My workaround: activate flight mode, than immediately deactivate it and the exclamation mark is gone. ‘Flight mode’ is a strange thing though to have on a Fairphone: for the exact same reason I own a Fairphone, caring about this world and it’s future, I have never and would never fly in an aeroplane. The ‘Flight mode’ would be more aptly named ‘close wireless connections’.
TL;DR and too many details? Blame my autism for not being able to differentiate between the essentials and the details.
It just arrived!
Now it’s charging with the Fairphone charger I bought together with my FP1. Works perfectly. It’s really beautiful and I love the charging animation a lot. In the meantime, I’m going to get one of my SIM cards cropped and buy a micro SD.
I held my FP2 against a colleague’s Samsung Galaxy Alpha, which he keeps in a rubber bumper for protection - so it has a bumper like the FP2.
Same size, same screen size and quality, the FP2 is a little thicker (1 - 2mm?). The samsung feels a little “sleeker” as the FP2 cover has some distinct “edges”. About the same weight. I like the FP2 user interface better than samsung’s.
I love the transparent back.
Music sounds good to me too btw (without any warm up with pink noise … whatever). I guess it depends on the source material (I’m only playing high bit rate MP3, though through nice “shure” headphones). It does take a bit of confidence to push the headphone plug far enough into the socket though - quite tight!.
Screen jitter issue needs fixing of course (though grounding yourself to something “earthy” now and again does help. WiFi exclamation mark a pain - but FP2 isn’t the only device to suffer.
Very happy with it so far. I am so impressed that a cool little company like fairphone can produce something so professional - which in so many ways so much better than the big corps do.
Pink noise : I’m pretty sure you can find generators on the play store, or why not simply playing a pink noise FLAC or WAV ? I would be interested in your opinion, as some said here that the sound quality was not very good.
