Firmware System Buttons Unresponsive (Disappear) when any Bluetooth device is connected after Android 15 Update
AI Corrected Text. Corrected for grammar mistakes for easier Reading.
Fairphone 5
Android 15
Bulld #: FP5.VT2D.C.054.20250814
I’d like to get straight to the point. Every time Bluetooth peripherals such as keyboards, mice, game controllers, Fairbuds XL, and more are connected to my Android 15 Fairphone 5, they remain connected until I disconnect them. I’ve noticed that my back button disappears, and the on-screen controls often malfunction, causing songs to repeat indefinitely, shuffle off, and play/pause to disappear altogether. Other apps also seem to be affected. Every Media Player I Use is busted at the moment.
I’ve also experienced issues with the icons disappearing. Regardless of the app I’m playing, the main system buttons remain unless I force shut down the phone. This is the only solution that works for me, and I’ve had no luck with other methods.
I’ve included some screenshots as proof. Unfortunately, I’m not able to access online streaming platforms or connect them to my phone without causing issues. In fact, I’ve had to disable remote streaming to avoid being banned from Xbox Series X, which is a frustrating experience. Just being Worried of being disconnected from an online match is the reason to avoid it for the time being.
Ai Corrected Text. Corrected for grammar mistakes for easier reading.
Still having issues with my daily Driver. My phone has to be forced shut down every time I try to do anything. In order to give more information. I had to do it many times to get everything.
Don’t mind the device temperatures - any program as labor-intensive as AI, video editing, screen casting, and just playing video games can skew the numbers. Pocket Pal AI is always loaded in the background System tray. I use it a lot to correct mistakes in emails, letters, etc. A very useful tool.
Besides, I know bug reports go on this website. Buried in other articles until no replies can be posted in the report in question.
Device Info 3.4.0.0
Date Created 2025-09-09 12:55:50
Summary
Device
Device Name : Fairphone 5 5G
Model : FP5
Manufacturer : Fairphone
Device : FP5
Board : FP5
Hardware : qcom
Brand : Fairphone
Build Fingerprint : Fairphone/FP5/FP5:15/AQ3A.240912.001/VT2D:user/release-keys
System
Android Version : 15
Version Name : Vanilla Ice Cream
Released Date : September 04, 2024
Code Name : Android 15
API Level : 35
Security Patch Level : 2025-08-05
Bootloader : unknown
Build Number : FP5.VT2D.C.054.20250814
Baseband : QCM6490.LA.3.0-00031-STD.PROD-,QCM6490.LA.3.0-00031-STD.PROD-
Java VM : 2.1.0
Kernel : 5.4.274-qgki-gca7127692058
Language : English (en_US)
OpenGL ES : 3.2
Root Management Apps : No Apps Detected
SELinux : Unable to determine
Google Play Services : 25.34.34 (260400-800653487)
Vulkan : Supported (1.3)
Treble : Supported
Seamless Updates : Supported
CPU
SoC : fp5 (no)
no
Processor : QTI SM7325
CPU Architecture : 1 x 2.71 GHz
3 x 2.40 GHz
4 x 1.96 GHz
Supported ABIs : arm64-v8a, armeabi-v7a, armeabi
CPU Hardware : qcom
CPU Type : 64 Bit
CPU Governor : schedutil
Cores : 8
CPU Frequency : 1 x 806 MHz - 2707 MHz
3 x 691 MHz - 2400 MHz
4 x 300 MHz - 1958 MHz
GPU Renderer : Adreno ™ 643
GPU Vendor : Qualcomm
GPU Version : OpenGL ES 3.2 V@0530.55 (GIT@923a446bf8, I23d7d7df15, 1725536844) (Date:09/05/24)
Battery
Health : Good
Level : 74%
Status : Discharging
Power Source : Battery
Technology : Li-ion
Temperature : 89.6 ℉
Voltage : 3899 mV
Network
Type : Wi-Fi
IP Address : 192.168.1.159
Gateway : 192.168.1.1
Subnet Mask : 255.255.255.0
DNS1 : 2600:1014:a021:44f0:aeb6:87ff:fe4b:74d0
DNS2 : 192.168.1.1
Lease Duration : 23H:33M
Interface : wlan0
Link Speed : 2161
Frequency : 6935
Connectivity
Bluetooth
Bluetooth : Supported
Multiple Advertisements : Supported
Offloaded Filtering : Supported
Offloaded Scan Batching : Supported
Bluetooth LE (Low Energy) : Supported
LE 2M PHY (High Speed) : Supported
LE Coded PHY (Long Range) : Supported
LE Extended Advertising : Supported
LE Periodic Advertising : Supported
LE Audio : Not Supported
Wi-Fi
WiFi Standard : Wi-Fi 6E
WiFi Direct : Supported
5GHz : Supported
6GHz : Supported
NFC
NFC : Supported
Secure NFC : Supported
Ultra Wide Band
Ultra Wide Band : Not Supported
USB
USB Host : Supported
USB Accessory : Supported
USB Debugging : Off
Display
Resolution : 2700 x 1224 Pixels
Density : 480 dpi (XXHDPI)
Font Scale : 1.0
Physical Size : 9.3 inches
Refresh Rate : • 60.0 Hz,• 90.0 Hz
HDR : Supported
HDR Capabilities : HDR10, HLG, HDR10+
Brightness Level : 24%
Brightness Mode : Adaptive
Screen Timeout : 1800 Seconds
Orientation : Portrait
Memory
Random Access Memory
Total : 7296.0MB
Available : 1670.0MB
Used : 5484.0MB
Used Percentage : 77%
System Storage
Total : 1.33GB
Available : 0.00GB
Used : 1.33GB
Used Percentage : 100%
Internal Storage
Total : 214.00GB
Available : 73.09GB
Used : 140.91GB
Used Percentage : 65%
External Storage
Total : 1430.21GB
Available : 0.24GB
Used : 1429.97GB
Used Percentage : 99%
Camera
Camera - 0
Position : Back
Mega Pixels : 13 MP
Resolution : 4096 x 3072
Focal Length : 5.56mm
Camera - 1
Position : Front
Mega Pixels : 13 MP
Resolution : 4088 x 3080
Focal Length : 3.23mm
Camera - 2
Position : Back
Mega Pixels : 13 MP
Focal Length : 2.19mm
Thermal
aoss-0-usr - 42000
aoss-1-usr - 42200
battery - 32000
camera-0-step - 41800
camera-0-usr - 41800
camera-therm-usr - 38826
chg-skin-therm-usr - 38697
conn-therm-usr - 31078
cpu-0-0-step - 43600
cpu-0-0-usr - 43600
cpu-0-1-step - 43600
cpu-0-1-usr - 43600
cpu-0-2-step - 43200
cpu-0-2-usr - 43600
cpu-0-3-step - 42800
cpu-0-3-usr - 42800
cpu-1-0-step - 42800
cpu-1-0-usr - 42800
cpu-1-1-step - 42000
cpu-1-1-usr - 42000
cpu-1-2-step - 44400
cpu-1-2-usr - 44800
cpu-1-3-step - 43200
cpu-1-3-usr - 42800
cpu-1-4-step - 43200
cpu-1-4-usr - 43600
cpu-1-5-step - 42800
cpu-1-5-usr - 42800
cpu-1-6-step - 42400
cpu-1-6-usr - 42400
cpu-1-7-step - 42400
cpu-1-7-usr - 42800
cpuss-0-usr - 43600
cpuss-1-usr - 43600
ddr-usr - 42600
gpuss-0-step - 41100
gpuss-0-usr - 41100
gpuss-1-step - 40300
gpuss-1-usr - 40300
mdmss-0-step - 27000
mdmss-0-usr - 40700
mdmss-1-step - 39100
mdmss-1-usr - 39100
mdmss-2-step - 39500
mdmss-2-usr - 39900
mdmss-3-step - 40300
mdmss-3-usr - 39900
mem-therm-usr - 39166
modem-lte-sub6-pa1 - 37000
modem-lte-sub6-pa2 - 27000
modem-mmw-pa1-usr - 27000
modem-mmw-pa2-usr - 27000
modem-mmw-pa3-usr - 27000
modem-mmw0-mod-usr - 27000
modem-mmw0-usr - 27000
modem-mmw1-mod-usr - 27000
modem-mmw1-usr - 27000
modem-mmw2-mod-usr - 27000
modem-mmw2-usr - 27000
modem-mmw3-mod-usr - 27000
modem-mmw3-usr - 27000
modem-skin-usr - 37000
modem-streamer-usr - 2000
msm-skin-therm-usr - 27000
nspss-0-step - 40700
nspss-0-usr - 40700
nspss-1-step - 39900
nspss-1-usr - 39900
pm7250b-ibat-lvl0 - 546
pm7250b-ibat-lvl1 - 390
pm7250b_tz - 38430
pm7325_tz - 37972
pm8350c-bcl-lvl0 - -274000
pm8350c-bcl-lvl1 - -274000
pm8350c-bcl-lvl2 - -274000
pm8350c_tz - 37000
quiet-therm-usr - 38109
rear-cam-therm-usr - 39133
sdm-skin-therm-usr - 40857
socd - 26
usb - 30000
vbat - 3886
video-step - 40700
video-usr - 40700
xo-therm-usr - 38668
Sensors
lsm6dso Accelerometer Non-wakeup
Vendor : STMicro
Type : ACCELEROMETER
Power : 0.17mA
lsm6dso Accelerometer Wakeup
Vendor : STMicro
Power : 0.17mA
mmc56x3x Magnetometer Non-wakeup
Vendor : memsic
Type : MAGNETIC FIELD
Power : 1.0mA
mmc56x3x Magnetometer Wakeup
Vendor : memsic
Power : 1.0mA
lsm6dso Gyroscope Non-wakeup
Vendor : STMicro
Type : GYROSCOPE
Power : 0.55mA
lsm6dso Gyroscope Wakeup
Vendor : STMicro
Type : GYROSCOPE
Power : 0.55mA
stk_stk3a5x Ambient Light Sensor Non-wakeup
Vendor : sensortek
Type : LIGHT
Power : 0.09mA
stk_stk3a5x Ambient Light Sensor Wakeup
Vendor : sensortek
Type : LIGHT
Power : 0.09mA
stk_stk3a5x Proximity Sensor Non-wakeup
Vendor : sensortek
Type : PROXIMITY
Power : 0.1mA
stk_stk3a5x Proximity Sensor Wakeup
Vendor : sensortek
Type : PROXIMITY
Power : 0.1mA
gravity Non-wakeup
Vendor : qualcomm
Type : GRAVITY
Power : 0.515mA
gravity Wakeup
Vendor : qualcomm
Type : GRAVITY
Power : 0.515mA
linear_acceleration
Vendor : qualcomm
Type : LINEAR ACCELERATION
Power : 0.515mA
linear_acceleration_wakeup
Vendor : qualcomm
Power : 0.515mA
Rotation Vector Non-wakeup
Vendor : qualcomm
Type : ROTATION VECTOR
Power : 1.415mA
Rotation Vector Wakeup
Vendor : qualcomm
Power : 1.415mA
mmc56x3x Magnetometer-Uncalibrated Non-wakeup
Vendor : memsic
Type : MAGNETIC FIELD UNCALIBRATED
Power : 1.0mA
mmc56x3x Magnetometer-Uncalibrated Wakeup
Vendor : memsic
Power : 1.0mA
Game Rotation Vector Non-wakeup
Vendor : qualcomm
Type : GAME ROTATION VECTOR
Power : 0.515mA
Game Rotation Vector Wakeup
Vendor : qualcomm
Power : 0.515mA
lsm6dso Gyroscope-Uncalibrated Non-wakeup
Vendor : STMicro
Type : GYROSCOPE UNCALIBRATED
Power : 0.55mA
lsm6dso Gyroscope-Uncalibrated Wakeup
Vendor : STMicro
Power : 0.55mA
sns_smd Wakeup
Vendor : qualcomm
Type : SIGNIFICANT MOTION
Power : 0.025mA
step_detect Non-wakeup
Vendor : qualcomm
Type : STEP DETECTOR
Power : 0.15mA
step_detect Wakeup
Vendor : qualcomm
Power : 0.15mA
pedometer Non-wakeup
Vendor : qualcomm
Type : STEP COUNTER
Power : 0.15mA
pedometer Wakeup
Vendor : qualcomm
Type : STEP COUNTER
Power : 0.15mA
sns_geomag_rv Non-wakeup
Vendor : qualcomm
Type : GEOMAGNETIC ROTATION VECTOR
Power : 1.05mA
sns_geomag_rv Wakeup
Vendor : qualcomm
Power : 1.05mA
sns_tilt Wakeup
Vendor : qualcomm
Type : TILT DETECTOR
Power : 0.025mA
lsm6dso Wakeup
Vendor : STMicro
Type : PICK UP GESTURE
Power : 0.026mA
Device Orientation Non-wakeup
Vendor : qualcomm
Type : DEVICE ORIENTATION
Power : 0.025mA
Device Orientation Wakeup
Vendor : qualcomm
Power : 0.025mA
stationary_detect
Vendor : qualcomm
Type : STATIONARY DETECT
Power : 0.025mA
stationary_detect_wakeup
Vendor : qualcomm
Power : 0.025mA
motion_detect
Vendor : qualcomm
Type : MOTION DETECT
Power : 0.025mA
motion_detect_wakeup
Vendor : qualcomm
Power : 0.025mA
lsm6dso Accelerometer-Uncalibrated Non-wakeup
Vendor : STMicro
Type : ACCELEROMETER UNCALIBRATED
Power : 0.17mA
lsm6dso Accelerometer-Uncalibrated Wakeup
Vendor : STMicro
Power : 0.17mA
stk_stk3a6x Ambient Light Sensor Non-wakeup
Vendor : sensortek
Type : PRIVATE SENSOR
Power : 0.09mA
stk_stk3a6x Ambient Light Sensor Wakeup
Vendor : sensortek
Power : 0.09mA
Apps
FUTO Voice Input
org.futo.voiceinput
Version : 1.3.6
iPlayVR Pro
com.panagola.app.iplayvrpro
Version : 2.0
LumaFusion
com.luma_touch.lumafusion
Version : 2.3.1
Xbox
com.microsoft.xboxone.smartglass
Version : 2508.2.12
Nintendo Music
com.nintendo.znba
Version : 1.3.0
Nintendo Switch App
com.nintendo.znca
Version : 3.1.0
Nintendo Switch Parental Controls
com.nintendo.znma
Version : 2.2.0
Pokémon Sleep
jp.pokemon.pokemonsleep
Version : 2.12.0
Sonic 4 episode 2
com.sega.sonic4episode2
Version : 3.0.0
7Zipper
org.joa.zipperplus7
Version : 3.10.96
3DMark
com.futuremark.dmandroid.application
Version : 2.6.5005
Sonic
com.sonic.sonicdrivein
Version : 5.66.0
Speedtest
org.zwanoo.android.speedtest
Version : 6.3.0
Game Pass
com.gamepass
Version : 2503.7.321
Brave
com.brave.browser
Version : 1.82.162
KDE Connect
org.kde.kdeconnect_tp
Version : 1.33.4
FE File Explorer
com.skyjos.apps.fileexplorer
Version : 4.7.1
Home Assistant
io.homeassistant.companion.android
Version : 2025.8.7-full
Amazon Music
com.amazon.mp3
Version : 25.18.5
org.chromium.webapk.af481b159e781106d_v2
Version : 2
Wayback Machine
com.archive.waybackmachine
Version : 1.4.5
FUTO Keyboard
org.futo.inputmethod.latin.playstore
Version : 0.1.25-playstore
Yahoo Mail
com.yahoo.mobile.client.android.mail
Version : 7.71.1
FCast Receiver
com.futo.fcast.receiver.playstore
Version : 42-playstore
Cardboard
com.google.samples.apps.cardboarddemo
Version : 3.5
Crazy Taxi Classic
com.sega.CrazyTaxiplayhaven
Version : 6.0
Pokémon GO
com.nianticlabs.pokemongo
Version : 0.377.1
Edge
com.microsoft.emmx
Version : 139.0.3405.125
Scout Maps
com.telenav.app.android.scout_us
Version : 4.6.3.18.3
ReadEra
org.readera
Version : 25.09.02+2190
Pikmin Bloom
com.nianticlabs.pikmin
Version : 127.0
Harbor
org.futo.harbor_flutter
Version : 11.0.0
Apple Music
com.apple.android.music
Version : 4.9.7.2
Google Play Music
com.google.android.music
Version : 8.29.9113-1.W
Privacy
com.privacy.pay
Version : 3.3.8
LionChief
com.lionel.lionchief
Version : 2.6.30
Battery Widget Reborn 2025
net.hubalek.android.reborn.beta
Version : 5.1.4/FREE
PrivateVPN
com.pvpn.privatevpn
Version : 4.1.10
Android System Key Verifier
com.google.android.contactkeys
Version : 1.219.791156583
Fairbuds
com.fairphone.android.fairbudsapp
Version : 2.1
Street View
com.google.android.street
Version : 2.0.0.484371618
LionChief Universal Remote OTA Firmware Updater
com.lionel.lioneluniversalremote
Version : 1.3.31
Carrier Services
com.google.android.ims
Version : carrierservices.android_20240520_00_RC00.phone
Twitch
tv.twitch.android.app
Version : 25.9.1
Grayjay
com.futo.platformplayer.playstore
Version : 336
Google Wallet
com.google.android.apps.walletnfcrel
Version : 25.34.797623885
Immich
app.alextran.immich
Version : 1.141.1
Minecraft
com.mojang.minecraftpe
Version : 1.21.101.1
Kodi
org.xbmc.kodi
Version : 21.2
PocketPal
com.pocketpalai
Version : 1.10.24
MS. PAC-MAN by Namco
com.NamcoNetworks.MsPacMan
Version : 2.6.0
Netflix
com.netflix.mediaclient
Version : 9.32.0 build 8 63348
VLC
org.videolan.vlc
Version : 3.6.5
Pokémon HOME
jp.pokemon.pokemonhome
Version : 3.4.2
Asphalt 7
com.gameloft.android.ANMP.GloftA7HM
Version : 1.1.1
Asphalt 8
com.gameloft.android.ANMP.GloftA8HM
Version : 8.5.0j
Asphalt
com.gameloft.android.ANMP.GloftA9HM
Version : 46.1.1a
Wave Live Wallpapers
com.wave.livewallpaper
Version : 1.1.3-wsm
Voice
com.google.android.apps.googlevoice
Version : 2025.08.24.799734347
Sonic 2
com.sega.sonic2.runner
Version : 2.0.4
M365 Copilot
com.microsoft.office.officehubrow
Version : 16.0.19127.20172
Facebook
com.facebook.katana
Version : 529.0.0.44.73
Prime Video
com.amazon.avod.thirdpartyclient
Version : 3.0.421.1247
RCT Classic
com.atari.mobile.rctclassic
Version : 1.2.25
Steam
com.valvesoftware.android.steam.community
Version : 3.10.5
SonicForces
com.sega.sprint
Version : 5.10.1
Ultimate USB
com.mixapplications.ultimateusb
Version : 9.0.1
PS Remote Play
com.playstation.remoteplay
Version : 8.0.0
Messenger
com.facebook.orca
Version : 523.0.0.53.109
Device Info
com.ytheekshana.deviceinfo
Version : 3.4.0.0
PS App
com.scee.psxandroid
Version : 25.8.1
QR Reader
uk.tapmedia.qrreader
Version : 3.0
SmartThings
com.samsung.android.oneconnect
Version : 1.8.34.21
Othello
com.litegames.othello
Version : 4.10.6
Translate
com.google.android.apps.translate
Version : 9.16.17.799522718.4-release
Adobe Acrobat
com.adobe.reader
Version : 25.8.2.40935
SonicDash
com.sega.sonicdash
Version : 8.12.0
Chess
com.jetstartgames.chess
Version : 2.8.9
GPay
com.google.android.apps.nbu.paisa.user
Version : 295.1.1 (arm64-v8a_release_flutter)
Fitbit
com.fitbit.FitbitMobile
Version : 4.50.fitbit-mobile-1103781861-800195270
Health Connect
com.google.android.apps.healthdata
Version : 2025.07.24.02.release
Equalizer
com.jazibkhan.equalizer
Version : 6.3.5
Google Play Books
com.google.android.apps.books
Version : 2025.7.25.6 (304086)
Tubi
com.tubitv
Version : 9.35.1
Android System SafetyCore
com.google.android.safetycore
Version : 1.0.780511585
Wear OS by Google
com.google.android.wearable.app
Version : 2.66.107.587544675.gms
Sonic Boom
com.sega.sonicboomandroid
Version : 3.18.2
GameStop
com.gamestop.powerup
Version : 500.14.8
Home
com.google.android.apps.chromecast.app
Version : 3.39.51.0
iHeartRadio
com.clearchannel.iheartradio.controller
Version : 10.55.0
Sonic CD
com.sega.soniccd.classic
Version : 4.0.0
Epson iPrint
epson.print
Version : 7.13.1
GasBuddy
gbis.gbandroid
Version : 701.28.25139
Nintendo.com
org.chromium.webapk.a55b009b8c4dee919_v2
Version : 1
Google VR Services
com.google.vr.vrcore
Version : 1.23.265693388
myChevrolet
com.gm.chevrolet.nomad.ownership
Version : 7.16.0
tzumiLED
com.lenzetech.colorfulled
Version : 1.0.4
Google Wi-Fi Provisioner
com.google.android.apps.carrier.carrierwifi
Version : 1.6.1.771193226
Authenticator
com.azure.authenticator
Version : 6.2509.5952
iTech Wearables
itech.wearables
Version : 2.2.1
DeleteMe Android
com.abine.deleteme
Version : 1.2.3-SNAPSHOT
TCL Home
com.tcl.tclhome
Version : 5.1.4
Paramount+
com.cbs.app
Version : 15.2.0
Google Pixel Watch
com.google.android.apps.wear.companion
Version : 4.0.0.792595430
Robokiller
com.robokiller.app
Version : 24.7.7
Google Play Games
com.google.android.play.games
Version : 2025.03.60115 (780469770.780469770-190400)
Turnip Calculator
org.chromium.webapk.ad959095b5d109b99_v2
Version : 1
Payment for FUTO Keyboard
org.futo.keyboardpayment
Version : v2
Google News
com.google.android.apps.magazines
Version : 5.139.0.791772586
YouTube TV
com.google.android.apps.youtube.unplugged
Version : 9.34.1
Find Hub
com.google.android.apps.adm
Version : 3.1.399-8
1Weather
com.handmark.expressweather
Version : 11.3.5
Revo Launcher
com.karuzohikari.wiiphone
Version : 5.2.3
Disney+
com.disney.disneyplus
Version : 4.14.0+rc3-2025.08.22
Annke Vision
com.anni.annkevision
Version : 6.2.51.0527
Google Earth
com.google.earth
Version : 10.89.0.3
Just Player
jp.co.kayo.android.localplayer
Version : 4.1.120
Sonic 1
com.sega.sonic1px
Version : 4.0.4
Kindle
com.amazon.kindle
Version : 8.129.0.100(2.0.51515.0)
ReadEra Premium
org.readera.premium
Bug Report System firmware.
Basically all on screen function buttons are not responsive after Android 15 Update. With any Bluetooth Device that connects to it. forcing me to force shut down the phone in order to do anything else with it. there was an update that supposedly fixed it but I found out its still there. no matter What Bluetooth Device is connected.
Any Media Player i use also has the on screen buttons stuck at repeat 1, shuffle off and unable to play and pause at all. so even common everyday tasks are broken.
Build number FP5.VT2D.C.054.20250814 as of writing. difficult to use my daily driver while any bluetooth device is connected witch is all the time for my pixel watch. any helpfull device would be handy.
Hi, I haven’t seen this.
[EDIT - After checking, yes I did see this once or twice.
For me, restarting the phone was sufficient to get rid of the problem.
I didn’t notice any association with Bluetooth.
There is also another topic on a similar subject here but it’s about FP6, not FP5. @Digimon Would you say your problem is the same?]
Make sure you raise a ticket with official Support. contactsupport
Which update?
Did you try factory reset ?
If not, you should. Make a backup before of course.
The fact it’s similar but it effects every bluetooth device I use makes it seem updating to Android 15 broke the bluetooth stack in relation to to firmware. No matter if it’s a wireless controller to watch.
I also noticed that it has used more System Ram and generates more device heat. Making multitasking very unreliable. Seeing my device have 6 out the available 8GB used when only two or three apps are open makes me think it’s more firmware based.
Required apps to be open is Fitbit, Itech Wearables, and one other to cause the bug to appear. They run background tasks. Closing them will break the communication. Which is fine in the short term. The bug makes all system tray icons to not function. Making redos of already written work a lost cause. I had to move my workload to desktop lately. But when I game with my wireless controller with bluetooth headphones. The connection to the Google watch and itech device also makes it appear. Really noticed it lately with remote streaming. As that freezes the device completely. The System RAM is full for some weird reason. The fact that this was not a problem on 14 makes me think it’s also firmware based. Keep in mind only three open apps when the phone can have six open at once.
Even posting here has caused problems. I try to post and it says not enough RAM post was unsuccessful rings alarm bells. Force shutting down by holding the power button just fixes it short term. I’ll come back on PC for posting anything related as I far well know it will crash if opening another app. See you in a bit
System is corrupted cant get files off device as easy. since two of my topics on the issue were merged here. I dont need to show everythng. just the specs. noticed that info on the issue was removed. hope these two screenshots along with the failed retrieval of info that made it don’t also get removed because its relevant to what i’m experiencing.
More than likely the upgrade is causing overheating. when starting the phone has 4.5 GB Used on launch. just doing anything as stated prior maxes out the Ram. more than likely the update itself was corrupted. a factory reset will only wipe it to a clean state. not fix the OS itself. that will require a OS file and knowlege of reloading the image on the phone. I find guides doesn’t explain it enough. a video would help a noob in this one.
with the upcoming surgery i have. it would have been useful as a hot Spot. all the wildfire smoke this year has caused tumors that are making it hard to breathe thus needing surgery to remove them. a rough year for me. oh well. If it still works later. all I can say is try it. the only thing I’d loose is my cell information. that would mean More trips to the carrier to restore my phone numbers. last time took weeks to fix. all over E-Sim problems in the end. not a fun time anyway. thankful to have everything backed up to restore them at a later time.
