Hello, I’m using the “old-way” of navigations with the 3-button layout, however since the last software update to Android 16 I’m unable to change their order.
You have the default “return-home-window” order, but I’ use the reversed one (window-home-return), and it doesn’t work when I try to enable the dedicated parameter in the settings. Do you know if it’s already a known issue ?
