My Fairphone 5 is not charging properly after only one week. Using Qualcom charger
You didnāt set the 80% charge limit by any chance?
Try to switch of Battery Protection if it is on.
My new FP5 charged properly for 4 days. Now it charges only to 79%. I let it discharge completely and then once it charged to 100% but last night again, I plugged it in at 22% and it does not go past 79%. Using QC3 Charger. The phone is 10 days old
bingo! thanks a million
Hi, I have a strange problem: my new FP5 (bought in October 2023) does only charge up to max 79/80% . I have tried different cables, different chargers, different contacts, installed the latest update⦠Since ca 4 weeks ago the battery never charges upp to 100%.
It always stops at 79%. Is there a ālimit buttonā somewhere, which I have missed? It is very strange. Anyone who has an idea how I can fix this problem?
Thereās an battery safety feature in settings, battery part. There you can limit charging to 80%, and also limit the current used for charging. Itās probably on in settings, cannot say whether the default changes, as Iām having it on for both
Thank you for superfast answer! This is the solution!
Have a wonderful day!
I have moved your post here.
Please see above.
Have you tried turning Battery Protect ON and then OFF again?
I think I did the on off switch already before my post. I did it also after my post and Iām observing whether the issue would occure again.
After 8 days I saw the issue again. I continue to post here my observations.
So what happens, the setting to charge only to 80 is enabled somehow? Is it possible this happens with a reboot?
No, the setting is still disabled. Also, Iām not going to reboot my device once a week in the hope I can avoid a semi loaded phone.
Since i use my FP5, it only charges to 79% (with battery savings option enabled). Sometimes it charges to 80%, but this is rarely.
It doesnāt matter if i use fast- or slow-charging.
Please try to turn battery protection on and then off again. You never know that might helpā¦
Done.
But donāt misunderstand me: I want to have battery protection on ond not off. I only want to point to the difference between 79% and 80% ![]()
Greetings
Dominion
Hi Weibelt,
I have the same issue when usin the Fast Charging Mode. Even though the battery protection is OFF, the battery gets stuck at 77% or 79%.
With normal charge mode it works perfectly fine.
I have tried rebooting the phone and turning On and Off the battery protection, but it still happens.
Sometimes it charges up to 100% with fast charging, but it rarely happens.
Are you still having the same issue? Maybe yours and mine are related.
