English
Fairphone 3 - Subjective First Week Impressions
Hi.
I have managed to get the Fairphone 3+ through my employer and bought the case and screen protector myself and now have been using it for a couple of days.
Since I am switching from a smaller Pixel 2, it still kind of feels a bit bulky. I really wish there were phones with smaller screens. Bezels do not bother me, but being able to hold it comfortably in one hand would be nice. Pixel 2 was not that much smaller but still a bit smaller.
The one thing that was surprising to me was the location of the speaker. While using the phone, depending on the task, I might use my right or my left hand. So when I use my left hand, often it will cover the speaker. So in my opinion a speaker facing down would have been a better choice.
The performance of the phone is OK but I do feel the difference that some applications, like Outlook takes a noticeably longer time to start, in my case, it takes 3-4 seconds. Not that bad but still noticeable for a phone that released 3 years after Pixel 2.
The camera experience is close to that of Pixel 2. Without optical stabilization, it is not possible to take pictures while zooming in. I actually would gladly pay extra for a camera module with optical stabilization option if it will be available in the future.
I like protective case wrapping a bit around the corners, adding extra protection to the edges.
I should say that overall the feeling about the phone is about what I expected. I have not found anything that stops me from using it as a daily driver. And the battery, headphone jack, open bootloader, environment, fairtrade, modularity, and repairability (not in the order of importance) makes me feel that I made the right choice for the next 4-5 years.
Good job, Fairphone team!
Hi just to say there are three issues that crop up often
a) battery charging issues with non ideal cables and chargers.
b) the quality of the images using the default camera app
and
c) Issue of audibility for the person you are calling if using hands free or WhatsApp for example. This is a recognised software issue that has occurred apparently after an update and is in the pipeline for a fix.
Glad you are happy with your decision to buy Fair :slight_smile:
Thanks for the reply and tips.
as about a - charging cable issues, I actually have experienced some difficulties with charging. I have a couple of [way overprised] Volta magnetic charging cables and tips and I had to find a certain combination for it to work. It indeed seems to be more “picky” about the cables.
as about b - the quality of the default camera app. I have not looked closely at the pictures but found that Open Camera experience seemed more public. It is almost as bad as Pixel 2 in low-light scenarios. I could say it is good enough for me though, as my expectations were not that high anyways. I will try NGCam, thanks!
as about c - handsfree problems, I have not tried handsfree yet. I will probably be using the wired headset from time to time. I might try the BT ones with Signal at some point.
Thanks!
An update.
First, the headset and loudspeaker.
I tried to use Skype with the loudspeaker and that is sort of useless.
I tried calling through Signal IM with 2 types of wired headsets and in both cases, it produced an echo for the person on the other side (who is not using FP). The person could hear himself with a second or so delay. I would not expect that with a [wired] headset. Talking without the headset worked as expected.
Doing normal calls works okay with the headset, so it is a problem when using apps like Skype or as it was mentioned WhatsApp or Signal in my case. I hope it is going to be fixed at some point.
Second, the performance.
I have noticed that when using home/work profiles, starting the application from a different profile can take around 5-7 seconds, and during that time it freezes.
Would it be right to say that this is not a problem with the performance of the hardware but rather software since the phone can run Minecraft smoothly for example, but it takes 5 seconds to start an application? Any thoughts?
It is a problem if you are walking and the top mic is pointing away from you, on a desk where I’m talking across the top mic it is fine. The bottom mic doesn’t get used in hands free video calls etc and the top mic is very quiet compared to the bottom one. You can see the diff.
Dial *#*#66#*#* and then select Service tests > Test single > Microphone
Fairphone have recognised this, apparently it happened with update 0066 and hasn’t been fixed.
I see there’s a new update, let’s hope it helps ?
